<esri:Map id="map"> </esri:Map>
<fx:Component id="dateField"> <!--<fieldClasses:CalendarField dateFormat="shortDate" useUTC="false"/>--> <fieldClasses:TextField minWidth="200"/> </fx:Component>
@namespace esri "http://www.esri.com/2008/ags"; esri|AttributeInspector, esri|RelationshipInspector #attributeInspector { skinClass: ClassReference("skins.AttributeInspectorSkin"); }
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" applicationDPI="160"> <esri:Map id="map"> </esri:Map> </s:Application>
You'll need to add a reference to the mx.swc. See:https://developers.arcgis.com/en/flex/guide/mobile-flex.htm
The other option mentioned at the bottom of that link is to remove references to the RelationshipInspector in the PopUpRendererSkin. The RelationshipInspector uses the AttributeInspector which by default, uses mx components like DateField. This has been an issue since 3.1, but now with 3.4, you're getting the error right away.
<fx:Component id="dateField"> <!--<fieldClasses:CalendarField/> --> <fieldClasses:TextField minWidth="200"/> </fx:Component>
<ns:Map id="map"> </ns:Map>
That was it. I used "default" instead of "defaults". Renaming it and running a clean made it all work. Thanks for all of your help with this. It is very appreciated.
<fx:Component id="memoField"> <fieldClasses:MemoField minWidth="200"/> </fx:Component>
<fx:Component id="memoField"> <fieldClasses:TextField minWidth="200"/> </fx:Component>
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
