Cameron, Are you manually setting the font in your main config.xml or in the default.css?
Cameron, Have those machines had the font size in the browsers increased or the standard windows DPI changed to 120? The only time I have seen that issue is when the font size is too big to fit the More... into the button.
I tried this map in IE, Firefox and Chrome and the More came up properly in all three.
How did you get it to show up on an Android browser?
Actually, I'm finding that if I go to the url http://maps.sanbag.ca.gov/flexviewer/index.html then I will get the error. Going to just /flexviewer everything loads normally. I was only loading index.html at times so that I could add a config parameter to the url. Perhaps something is wrong with my index.html file. However, I'm finding that everything looks normal when I try maps.sanbag.ca.gov/flexviewer/default.htm instead of index.html. Default.htm was higher up the list in the default document priority.So I guess everything is fixed, although I have no idea what was wrong with the index.html file.
I'm not sure how/where to tell flashbuilder to build an index.html instead of a default.html, but none of my projects even have a default.html, just the index.html.You may try deleting your project from the server and re-export a release build again and see if it writes a correct index.html file without the "issue", especially since that is higher in the default document lists.R_
