Thank U Jeremiah Nieves for your great post , i really appreciate that also the research link was really helpfulcould you please provide your python code or which tools to create the connector feature class automatically as i have more than 70 route with 1500 bus station
#Jeremiah: I have seen your pdf. Why for bus and stop haven't use subtype in connectivity? so you have 1 feature class bus and 1 feature class stop.
Jeremiah,Do the routes have to be offset? And if so, how do you offset them?
Thanks for the help so far. So I offset my routes by using Editing and then Move and it allowed me to move them a specified distance. Now I have built a network of just bus routes, but my stops and connectors don't seem to be working. What connectivity policy should I have? I used the one in the paper you referenced as a guide. I'll attach an image of my problem. Also you'll see in the Connectors image that the Real Stop are connected in a linear fashion as opposed to radial, is this correct? Also, when building the Network Dataset, do I build the Z Elevation?[ATTACH=CONFIG]26456[/ATTACH][ATTACH=CONFIG]26457[/ATTACH]
