Ok this is the second time I have posted on this topic and I am reposting because this is having a massive impact on our work. We can not get the raster to polygon tool working. I have tried using .ecw, jpg, .tiff, .GeoTif nothing works. I have left the tool running all weekend and com back on monday and the tool is still going. I have even used my work mates pc and ran it for 8 days and nothing. I have tried it on small images big images single tiles and the same result the tool just will not work. Any ideas and anyone know how to register this issue with ESRI? Running 10.1 SP4.
It is critical that the end polygon does not cover the white area in the photo. Just the actual picture part not the white part. I can get a polygon of the whole area with white part inclueded no problem from the footprints. Let me Know if this helps and how to prceed.
These files are 3 Band .tif. I have about 8000 of them organised in a Mosaic dataset for viewing. When put together they cover an area of about 2000Km long and 500 Meters wide. I can of coarse break this task into smaller sections but as I said I can not get the tool working on even 1 single .tif. I need a polygon to measure how much aerial photos (in Meters Squared) we have recieved from a sub contactor. Attached is an image of one of the .Tif files. It is critical that the end polygon does not cover the white area in the photo. Just the actual picture part not the white part. I can get a polygon of the whole area with white part inclueded no problem from the footprints. Let me Know if this helps and how to prceed.
The tifs can be displayed but it is not suitable for data converting by using ESRI geoprocessing tools.
Hi,If that is what you are trying to get, I would not suggest you raster to polygon. Instead, you can use build footprint tool to get rid of the white areas from your images in a mosaic dataset. Once the footprints are built, you should be able to calculate the area from them or export them as necessary. Please note that you might have to play with the parameters to get an accurate footprint. I would assume that the white pixels are 255, so you would want to use a value lesser than or equals to 254 for the maximum data value (which will exclude white pixels for footprint calculation). Also, make sure that the maintain sheet edge option is checked on as it will only get rid of the white pixels form the border areas. It's best to test the tool with smaller subset of your images before you run it for entire mosaic dataset. It's also better to run the tool before you build the mosaic dataset overviews. [ATTACH=CONFIG]27272[/ATTACH]*Hope this helps!Prasanta.
