I'm trying to create a new level of data on my map but ArcMap will only recognize .shp files, how can I fix this? I already decompressed the entire .zip folder.
Okay so I moved the .dbf file, for example, to another directory, but when it opened a General Failure Message appeared on the bottom right of the screen and messed everything up. HELP!!!
Hi Kaylani,
What are you trying to do exactly? What files do you need to open? If you're having issues with data files, can you post them here in an attachment so that others can try too? What version of ArcMap are you running?
Are you trying to open shapefile data or adding other (non shapefile) data?
If a shapefile, sounds like you are trying to move one of the component files of a shapefile . A "shapefile" actually consists of several separate files (as seen in Windows Explorer). Basic shapefile will have four files - .shp, .shx, .dbf, .cpg - with potentially others (e.g. a .prj file if the files has a coordinate system described for it). All the files must be in the same folder location and cannot be separated.
If you are trying to add other data (e.g. .dbf file of point data which has coordinates) try adding through File > Add Data > Add XY Data - you can select the data location and match the XY coordinates to the relevant dbf file field names.
I downloaded a .zip folder which contains all of the formats you just mentioned, but when I open the decompressed file folder on ArcMap only the .shp file shows up. Is this normal or are the other types of files supposed to show?
I'm just trying to know if just the .shp files are the only ones that ArcMap will open up in the folder, even if the .zip file contains other types of file formats. Here are the files of the first .zip folder I tried.
if all you have is a file with a *.shp file extension and not a similarly named file with a *.dbf and a *.shx extension... then it was improperly zipped and is useless... to clarify a shapefile will consist of at least 3 files ...
test.shp, test.dbf and test.shx and there can be others with the same name, but differing extension.
Check this
https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0ahUKEwj7_O23i_DOAhVJI8AKHTF_CmwQFg…
About geographic data formats—Help | ArcGIS for Desktop
they are the files for one shapefile... why did you zip them individually? they all constitute the RCRPER_EPA shapefile.
Once you use the Add Data tool to load it into arcmap, you can then right-click on the layer in the table of contents of the data frame, the Open the table for the shapefile... that is how you access the tabular information
Thank you so much!
Hope it worked out
Patience of Job, Dan_Patterson
