<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>layer infos</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script> <script type="text/javascript"> dojo.require("esri.map"); function init() { var map = new esri.Map("map"); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var url = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServer/"; var dynLayer = new esri.layers.ArcGISDynamicMapServiceLayer(url); map.addLayer(dynLayer); dojo.connect(dynLayer, "onLoad", function() { var infos = dynLayer.layerInfos; for (var i = 0; i <= infos.length - 1; i++) { var layerId = infos.id; var restEndPoint = url + layerId; //restEndPoint is the layer's URL - how can I retrieve its fields? } }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div> </body> </html>
If available
If available, you could use the '/layers' REST endpoint to get back all the information you need in a single call.
If available, you could use the '/layers' REST endpoint to get back all the information you need in a single call.<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Create Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script> <script type="text/javascript"> dojo.require("esri.map"); function init() { var map = new esri.Map("map"); var imageParameters = new esri.layers.ImageParameters(); imageParameters.format = "jpeg"; var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServer", { "opacity":0.5, "imageParameters":imageParameters }); map.addLayer(dynamicMapServiceLayer); // GET MAP SERVICE INFORMATION getMapServiceInformation(dynamicMapServiceLayer.url); } // GET MAP SERVICE INFORMATION function getMapServiceInformation(mapServiceUrl) { var mapServiceInfoDeferred = esri.request({ url: dojo.replace("{0}/layers",[mapServiceUrl]), content: { f: 'json' }, callbackParamName: "callback" }); mapServiceInfoDeferred.then( function(response) { // THE INFORMATION RETURNED HERE IS NOT THE SAME OBJECT/INSTANCE AS // THE JS API LAYER CREATED ABOBE, IT'S JUST A SIMPLE JSON OBJECT // REPRESENTATION OF MAP SERVICE INFORMAITON dojo.forEach(response.layers, function(layerInfo) { var layerInfoNode = dojo.create('li', { 'innerHTML': dojo.replace("<b>{name}</b> [{type}]",layerInfo), 'style':'font-size:larger;margin-bottom:20px;' },'mapServiceInfo'); if(layerInfo.fields) { var fieldsInfoNode = dojo.create('ul', { },layerInfoNode); dojo.forEach(layerInfo.fields, function(fieldInfo) { var fieldInfoNode = dojo.create('li', { 'innerHTML': dojo.replace("<b>{name}</b> (<i>{alias}</i>) {type}",fieldInfo) },fieldsInfoNode); }); } }); }, function(error) { dojo.byId('mapServiceInfo').innerHTML = dojo.toJson(error); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="map" style="width:500px; height:300px; border:1px solid #000;"> </div> <ul id="mapServiceInfo"> </ul> </body> </html>
Storing the info in the MXD is a good workaround, but I need something guaranteed to work (ie, without the dependency on the MXD author to remember to make the change).What about doing something with a JSON request, like in this sample? Do you think this would work?The URL http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServer/layers?f=json returns a JSON string containing the field names, but I can't work out how to access this using the JSON request methodology in that sample. Can you give any clues?Cheers,Steve
See the sample below, which adds a DynamicMapServiceLayer to a map using the URL:http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServerNavigating to this REST endpoint in a browser shows the component Layers, and each layer's Fields.How can I retrieve this information programatically? I need a list of the available layers (0,1,2) and each layer's available fields (eg layer 0 contains objectid, lifecyclestatus, incident_number, etc)My goal is to add this information to a Query function, so I need to know that I can search layer 1 for the field collection_time, etc.Looping through the layerInfos tells me about each available layer - how can I retrieve information on the fields? (One option is to create a new feature layer from each layer and add it to the map, but I'd really like to avoid this workaround).Thanks,Steve<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>layer infos</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script> <script type="text/javascript"> dojo.require("esri.map"); function init() { var map = new esri.Map("map"); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var url = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServer/"; var dynLayer = new esri.layers.ArcGISDynamicMapServiceLayer(url); map.addLayer(dynLayer); dojo.connect(dynLayer, "onLoad", function() { var infos = dynLayer.layerInfos; for (var i = 0; i <= infos.length - 1; i++) { var layerId = infos.id; var restEndPoint = url + layerId; //restEndPoint is the layer's URL - how can I retrieve its fields? } }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div> </body> </html>
