# make an empty master file WSTable = [] # open the file to read txt = open(r"c:\weights.txt", 'r') # read each line to the end of the file while txt.readline() != '': # readline gets a line line = f.readline() # rstrip removes carrige return strip = line.rstrip() # split makes sure you get the correct chunks split = strip.split(',') # now make a list of the chunks aList = list(split) # append the individual list to the master list WSTable.append(aList) # close the file txt.close()
wstbl = WSTable([["snow", "VALUE", 0.25], ["land", "VALUE", 0.25],["soil", "VALUE", 0.5]])
import arcpy from arcpy.sa import * arcpy.CheckOutExtension("Spatial") wstbl = WSTable([["snow", "VALUE", 0.25], ["land", "VALUE", 0.25], ["soil", "VALUE", 0.5]]) print wstbl
output_raster = arcpy.sa.WeightedSum(wstbl)
arcpy.gp.WeightedSum_sa("snow VALUE 0.25;land VALUE 0.25;soil VALUE 0.5",output_raster)
import arcpy arcpy.CheckOutExtension("Spatial") wstbl = arcpy.GetParameterAsText(0) # list of rasters and weights out_ras = arcpy.GetParameterAsText(1) # output raster arcpy.gp.WeightedSum_sa(wstbl,out_ras)
