Hi All,I am trying to practice accessing content from custom modules using the Home Button sample from the API tutorials. I have saved the HomeButton.js and the HTML page in the folder structure which is attached as images.I have written the following HTML page to load the HomeButton but I get an "Object doesn't support this action" error when the page attempts to create a new HomeButton object. I suspect that the issue is with the way I have entered the path to my custom module but I have tried loads of combinations and cant seem to find a solution.The code is below and any help would be greatly appreciated!Peter<!DOCTYPE HTML>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1">
<title>Home Extent Button Dijit</title>
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="./ERMWidgets/css/HomeButton.css">
<style type="text/css">
body{
margin:40px;
padding:20px;
.container{
position:relative;
padding: 10px;
border: 1px solid #eee;
-webkit-border-radius: 3px;
border-radius: 3px;
#map{
width:100%;
height: 500px;
position: relative;
#HomeButton{
position: absolute;
top:95px;
left: 20px;
z-index: 50;
</style>
</head>
<body class="claro">
<div class="container">
<div id="map" class="map">
<div id="HomeButton"></div>
</div>
</div>
<h2>All Options</h2>
<script src="http://js.arcgis.com/3.7/" type="text/javascript"></script>
<script type="text/javascript">
var dojoConfig = {
async: true,
parseOnLoad: true,
isDebug: true,
packages:[{
"name": "ERMWidgets",
"location": location.pathname.replace(/\/[^/]+$/, '') + "/ERMWidgets/"
require(["esri/map", "ERMWidgets/HomeButton", "dojo/on"], function(Map, HomeButton, on){
var myMap = new Map("map", {
center: [-56.049, 38.485],
zoom: 3,
basemap: "streets"
var myWidget = new HomeButton({
map: myMap
},"HomeButton");
myWidget.on('home', function(obj){
console.log(obj);
myWidget.startup();
</script>
</body>
</html>
