mxd = arcpy.mapping.MapDocument(r"C:\test.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "Wells", df)[0] arcpy.mapping.ExportReport(lyr, r"C:\CAD tables backup\CAD tables working\Reports\Wells.rlf", r"C:\CAD tables backup\CAD tables working\CAD tables\Wells.xls") ### lyr = arcpy.mapping.ListLayers(mxd, "Wells", df)[1] arcpy.mapping.ExportReport(lyr, r"C:\CAD tables backup\CAD tables working\Reports\Wells2.rlf", r"C:\CAD tables backup\CAD tables working\CAD tables\Wells2.xls") ### lyr = arcpy.mapping.ListLayers(mxd, "Wells", df)[2] arcpy.mapping.ExportReport(lyr, r"C:\CAD tables backup\CAD tables working\Reports\Wells3.rlf", r"C:\CAD tables backup\CAD tables working\CAD tables\Wells3.xls") ### lyr = arcpy.mapping.ListLayers(mxd, "Wells", df)[3] arcpy.mapping.ExportReport(lyr, r"C:\CAD tables backup\CAD tables working\Reports\Wells4.rlf", r"C:\CAD tables backup\CAD tables working\CAD tables\Wells4.xls")
lyrs = arcpy.mapping.ListLayers(mxd, "Wells", df) # did you fetch anything?: print 'Number of layers successfully fetched: ' + str(len(lyrs)) # print the lyr names you just fetched, if any: for lyr in lyrs: print lyr.name # now access them individually for further processing: for i in range(len(lyrs)): lyr = lyrs # this sets the lyr variable to layer index i in the range print lyr.name + ' can now be processed.' # you can add code for further processing here
