Dear all
I have same problem when i working with bathmetry river. I want to know elevation any point in river net i used . We can not interpolation by tool in arcmap.I used method like this
y(F) = ax(F)+b
y(O)=ax(O)+b
I posted the AddIn under a blog which is located here.
The link to your add in returns "Page not found"
I would like to use a similar method for locations along a corridor that I need the 3d length for. Before I was able to simply use the 2d length, but recently I have learned that I will need to get the 3d length values where the corridor sections intersect the centerline. The method I was using was relatively simple and is shown below.1. I would cut the polygon based on locations where methodology changed. 2. I would run the Locate Features Along Route tool.3. I would join the resulting table with the polygon layer with the input OID.4. Calculate the mileage for the from and to mileposts for the new polygons.Is there a way to use the 3d length of the route as opposed to the 2d length?Thanks for any help!LTK
