I have a two feature layer; property boundary and pond layer. I am developing javascript application that shows the two layers. I made hollow to the polygon boundary layer that helps to see pond layer overlaid on it. However is there way I can just display the ponds inside the property boundary layer without displaying outside of boundary layer. Any reference or code samples will be appreciated. Thanks
Yes, you can do this with polygon data. You will just need to use the Polygon class rather than the Point class. The below example selects all counties that intersect the state of Florida.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Sample Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css"> <style> html, body, #mapDiv { padding:0; margin:0; height:100%; } </style> <script src="http://js.arcgis.com/3.15/"></script> <script> var map; require([ "esri/map", "esri/layers/FeatureLayer", "esri/tasks/query", "esri/tasks/QueryTask", "esri/geometry/Polygon", "esri/SpatialReference", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "esri/graphic", "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/domReady!" ], function( Map, FeatureLayer, Query, QueryTask, Polygon, SpatialReference, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic, dom, on, array ) { map = new Map("mapDiv", { basemap: "streets", center: [-81.6182, 28.3678], zoom: 8 }); var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2",{ mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["*"], opacity: 0.75 }); featureLayer.setDefinitionExpression("state_name = 'Florida'"); map.addLayer(featureLayer); var query = new Query(); query.where = ["1=1"]; featureLayer.queryFeatures(query, function(featureSet) { geometry = featureSet.features[0].geometry; var query = new Query(); var queryTask = new QueryTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/3"); query.geometry = geometry; query.returnGeometry = true; queryTask.execute(query, function(graphic){ array.forEach(graphic.features, function(feature){ var polygonJson = {"rings": feature.geometry.rings, "spatialReference":{"wkid":4326}}; var polygon = new Polygon(polygonJson); var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255,0,0]), 2),new Color([255,255,0,0.25]) ); var graphic = new Graphic(polygon, sfs); map.graphics.add(graphic); }) }) }); }); </script> </head> <body> <div id="mapDiv"></div> </body> </html>
Hey Kushendra,
I think the only way to do this, is by running a query and selecting all ponds that are within a certain Polygon.
ArcGIS API for JavaScript Sandbox instead of the buffer polygon use your polygon.
Once they are selected make the symbology for the ponds that are not selected invisible and the symbology for the selected features what ever you like.
FeatureLayer | API Reference | ArcGIS API for JavaScript
Hope this helps
Tim
Hi Kushendra,
Below is an example. Using the QueryTask function, only the cities are returned that intersect Miami-Dade county.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Sample Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css"> <style> html, body, #mapDiv { padding:0; margin:0; height:100%; } </style> <script src="http://js.arcgis.com/3.15/"></script> <script> var map; require([ "esri/map", "esri/layers/FeatureLayer", "esri/tasks/query", "esri/tasks/QueryTask", "esri/geometry/Point", "esri/SpatialReference", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "esri/graphic", "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/domReady!" ], function( Map, FeatureLayer, Query, QueryTask, Point, SpatialReference, SimpleMarkerSymbol, SimpleLineSymbol, Color, Graphic, dom, on, array ) { map = new Map("mapDiv", { basemap: "streets", center: [-81.792107, 26.150807], zoom: 8 }); var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/3",{ mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["*"], opacity: 0.75 }); featureLayer.setDefinitionExpression("name = 'Miami-Dade'"); map.addLayer(featureLayer); var query = new Query(); query.where = ["1=1"]; featureLayer.queryFeatures(query, function(featureSet) { geometry = featureSet.features[0].geometry; var query = new Query(); var queryTask = new QueryTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0"); query.geometry = geometry; query.returnGeometry = true; queryTask.execute(query, function(graphic){ array.forEach(graphic.features, function(feature){ var point = new Point(feature.geometry.x, feature.geometry.y, new SpatialReference({wkid:4326})); var simpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 1), new Color([0,255,0,0.25])); var graphic = new Graphic(point, simpleMarkerSymbol); map.graphics.add(graphic); }) }) }); }); </script> </head> <body> <div id="mapDiv"></div> </body> </html>
Thanks for the info Tim. I was looking for script where I can interact with feature content to filter out the data on the client side.
Jake- that is great. This is something I need however, I experience problem on retrieving the exact polygon geometries. Is there way I can return polygon geometry ( not points) from the feature data that intersect with other polygon layer? In my data, there are numerous property boundaries (polygons) and I need to filter out ponds (polygon) in order to display only within those boundaries. I would be glad to get code snippets if you have. Thank you and appreciated your help
Jake I did exactly the way you did but still it did not return the pond geometries. In addition, do I need to add layer to display pond layer? It has only displayed boundary layer. You can check the script and let me know if I need anything.
<!DOCTYPE html>
<html>
<head>
on iOS devices-->
<style>
padding:0;
margin:0;
height:100%;
</style>
<script>
var map;
require([
], function(
Map, FeatureLayer,
Query, QueryTask,
dom, on, array
basemap: "topo",
center: [-97.144, 34.174],
zoom: 8
var featureLayer = new FeatureLayer("http:xyz/webgis/rest/services/Cooperators/cooperatorboundaryandpond/FeatureServer/0",{
outFields: ["*"],
opacity: 0.75
featureLayer.setDefinitionExpression("EntityID = '9410'");
var queryTask = new QueryTask("http:xyz/webgis/rest/services/Cooperators/cooperatorboundaryandpond/FeatureServer/1");
var polygonJson = {"rings": feature.geometry.rings, "SpatialReference":{wkid:102725}};
</script>
</head>
<body>
</body>
</html>
