we use our own COM categories in our extension
I don�??t have specifics on when the instructions will be released or what form it will be in, but it will probably be a blog or a KB doc.
We will provide documentation that will describe how customers can register their legacy components with ArcGIS 10. Like you said, ESRI will not provide support for this workflow, so if it doesn�??t work you will not be able to call Technical Support. There will be no guarantees that this registration process will work, and no guarantees that the component will work in the new version.
It appears to me that when you run the ESRIRegAsm tool that it produces a file in the following directory:C:\Program Files\Common Files\ArcGIS\Desktop9.4\Configuration\CATIDThe name of the file is something like {GUID}_name.ecfg. The file itself is really a zip file which contains a file named config.xml. It appears that ArcMap is using this file to determine component categories versus that which is in the registry.I did the following:1) Used the VB6 sample which has a tool bar, extension, and zoom in and out commands and built the DLL and reg file needed on a 9.3.1 system2) Tested the sample on 9.3.1; no problems3) Tested the sample on 9.4 using ESRIRegAsm; it does not work4) Went to the CATID directory, extracted the config.xml, manually repaired the XML, and put it back in the zip5) Tested the sample, no problemsESRI, why don't you provide a trivial tool which does this?
Hi Can you please tell me what is that you manually repaired in the XML. I am having the same problem. And when I look into the CATID directory I noticed the CLSID values dont match the values from the component catergories. I modified the values in the config.xml to match the Component Categories and tried to execute ESRIRegAsm using the syntax ESRIRegAsm /p:Desktop "MyDLL.dll" /f:"Config.dll" but didnt work.Thanks,Sirisha.
Private Sub btnTest_Click() On Error GoTo EH Dim vok As Boolean Dim lok As Boolean 'bind to an ArcGIS 10 version: Dim version As String version = "10.0" Dim vmgr As ArcGISVersionLib.IArcGISVersion Set vmgr = New ArcGISVersionLib.VersionManager vok = vmgr.LoadVersion(esriArcGISDesktop, "10.0") If Not vok Then Err.Raise 1, , "Unable to bind to ArcGIS version " & version End If 'now get a license: Dim ao As esriSystem.IAoInitialize Set ao = New esriSystem.AoInitialize lok = True If (ao.IsProductCodeAvailable(esriLicenseProductCodeArcInfo) = esriLicenseAvailable) Then ao.Initialize esriLicenseProductCodeArcInfo Else lok = False Err.Raise 2, , "Unable to get an ArcGIS Desktop license." End If 'report results: MsgBox "Bound to ArcGIS 10: " & vok & vbCrLf & "Got a license: " & lok ExitSub: Exit Sub EH: MsgBox Err.Description Resume ExitSub End Sub
The updated link to KB Article 37639 is 37639 - Register Legacy Components with ArcGIS 10
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
