Getting a black box this morning for USGS National Map layer failed to load on all my FlexViewer apps. Any information I missed or is it just down this morning? See attachment please.
Janie
It wasn't working unless your URL was listed in the
http://basemap.nationalmap.gov/crossdomain.xml
For now, we've removed that basemap from the default basemap gallery so there should be no more error messages about that service when starting your flexviewers.
Same here.
Logged in this morning and I am getting the same USGS National Map Layer error. Any suggestions?
Mike Toth
Apparently the problem is now fixed. This was either a security issue or the service was just down temporarily. I'm very happy to say my production FlexViewer web apps are now all working.
Thanks ESRI!
Thanks Bjorn. Everything is working fine now!Janie
This appears to be broken again? We are getting this error in all our viewers.
This morning all our FlexViewers were getting the black box on this basemap again. It is working now again.
Thanks ESRI,
Have just started getting this error again ... doesn't appear that we have much control over it from our end ???
We have been getting this since around July 3rd, 2017. We can't get any help from ESRI so far. It would be so helpful if Bjorn Svensson could once again remove that basemap from the default basemap gallery as he did in 2014 above. I have 20 different production Flex Viewers throwing this error everytime they start up that web app.
Thanks,Janie
I'm in the same boat, this error has been a problem since early July. I do not want to have to disable the basemaps portal to remove the error, but I cannot think of another way.
Janie Goddard Stephen Mitchell - do you have a public facing web app where this can be reproduced? Which browsers (on which platforms) does this happen in?
My web app is unfortunately not public facing, but I'm including a screenshot of the error I've been getting ...
The Esri example of the basemap widget errors also. https://community.esri.com/external-link.jspa?url=http://resources.arcgis.com/en/help/flex-viewer/live/index.html
Http://geodata.cherokee.org/cherokeenation
Firefox and I.e both throw this. These are flexviewers 3.7 on Server 10.2.1.
Sent from my iPhone
Hi Bjorn,
Is there any chance of you doing what you did in your response above on Dec 2014:
“For now, we've removed that basemap from the default basemap gallery so there should be no more error messages about that service when starting your flexviewers.”
We would so appreciate your help!
Thank you to ESRI for working with USGS to fix this problem. Thank you USGS!
Thank you ESRI for helping with this! Thanks Janie for getting this on the radar.
You're welcome Stephen! I know my users were not happy.
Yes, good to go here as well ... thanks again Bjorn!
Absolutely thanks Bjorn! Janie
Janie Goddard - I think the best option for now is to modify your config.xml files.
There are two possible solutions:(1) instead of using the default basemap group, point it to an organization that has all-except-USGS basemaps.
(2) instead of asking online/portal for the basemaps, hardcode them in your config.
In the map tag, change
addarcgisbasemaps="true"
to
addarcgisbasemaps="false" portalurl="https://YOUR-ORGANIZATION.maps.arcgis.com"
1. Change addarcgisbasemaps="true" to addarcgisbasemaps="false"
2. Add the basemaps (this might be slightly idfferent set from what you're used to - adjust as appropriate). Add it inside the map tag, before the operationallayers tag.
<basemaps> <layer label="Topo" type="tiled" visible="true" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/6e03e8c26aad4b9c92a87c1063ddb0e3/info/thumbnail/topo_map_2.jpg" url="https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> <layer label="Imagery" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/86de95d4e0244cba80f0fa2c9403a7b2/info/thumbnail/tempimagery.jpg" url="https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <layer label="Imagery with labels" type="tiled" visible="false" alpha="1" icon="assets/images/basemap_imagery_with_labels.png" url="https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <layer label="Imagery with labels" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/413fd05bbd7342f5991d5ec96f4f8b18/info/thumbnail/imagery_labels.jpg" url="https://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer"/> <layer label="Dark Gray Canvas" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/25869b8718c0419db87dad07de5b02d8/info/thumbnail/DGCanvasBase.png" url="https://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Dark_Gray_Base/MapServer"/> <layer label="Dark Gray Canvas" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/25869b8718c0419db87dad07de5b02d8/info/thumbnail/DGCanvasBase.png" url="https://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Dark_Gray_Reference/MapServer"/> <layer label="Light Gray Canvas" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/8b3b470883a744aeb60e5fff0a319ce7/info/thumbnail/light_gray_canvas.jpg" url="https://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"/> <layer label="Light Gray Canvas" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/8b3b470883a744aeb60e5fff0a319ce7/info/thumbnail/light_gray_canvas.jpg" url="https://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Reference/MapServer"/> <layer label="National Geographic" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/509e2d6b034246d692a461724ae2d62c/info/thumbnail/natgeo.jpg" url="https://server.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer"/> <layer label="Terrain with labels" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/aab054ab883c4a4094c72e949566ad40/info/thumbnail/terrain_labels.jpg" url="https://server.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer"/> <layer label="Terrain with labels" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/aab054ab883c4a4094c72e949566ad40/info/thumbnail/terrain_labels.jpg" url="https://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer"/> <layer label="Oceans" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/48b8cec7ebf04b5fbdcaf70d09daff21/info/thumbnail/tempoceans.jpg" url="https://server.arcgisonline.com/ArcGIS/rest/services/Ocean/World_Ocean_Base/MapServer"/> <layer label="Oceans" type="tiled" visible="false" alpha="1" icon="https://www.arcgis.com/sharing/rest/content/items/48b8cec7ebf04b5fbdcaf70d09daff21/info/thumbnail/tempoceans.jpg" url="https://services.arcgisonline.com/ArcGIS/rest/services/Ocean/World_Ocean_Reference/MapServer"/> <layer label="Streets" type="tiled" visible="false" icon="assets/images/basemap_streets.jpg" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <layer label="OpenStreetMap" type="osm" visible="false" icon="assets/images/basemap_osm.jpg"/> </basemaps>
Minor update: all the ArcGIS Online services are better accessed as https, so even the Street service should be https. So in my code block above
should be
https://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer
Thanks Bjorn for keeping us up!
