I'm using a 10.1 SP1 client. My test SDE database is 10.2...Anyone have any ideas?
7. Open a SQL window and run the command EXEC sde.version_util.set_current_version('MY_VERSION') -This is when I get an error ORA-00900: Invalid SQL Statement. -A coworker recommended trying to run this command in the PL/SQL command window as the following: BEGIN EXEC sde.version_util.set_current_version('MY_VERSION') END; -But then I couldn't figure out how to run the select statement and see a returned record.
Hello,late to the party, but stumbled over the same problem: BEGIN
sde.version_Util.Set_Current_Version('MY_VERSION');
sde.version_user_ddl.edit_version('MY_VERSION',1);
END;
/SELECT * FROM TABLE WHERE ID LIKE '123456';
BEGIN
sde.version_user_ddl.edit_version('MY_VERSION',2);
