I am building a script tool with a parameter 'Statistics Fields'.
properties as set as follow:
How do I enable the 'Add Value' button associated to this parameter?
Thanks
obtained from.... and the field would be obtained from the table or featureclass table.
Also, make sure that 'string' isn't the type of field that you currently have highlighted
Thanks Dan for this.
I realize that my question was not as clear and simple as I thought.
I fact, I am trying to set my Statistics Fields parameter as a list of values where the user can add new values using the 'Add Value' Button.
When the data type is defined as String I can set the property Filter as Value List and add default values.
I don't need to set the data type as Field because the values are not obtained from fields. Moreover, the available functionality is 'Add Field'. Similar but potentially misleading for the user
How do I enable this 'Add Value' button or what is the proper way to customize this intended behavior?
My read was you wanted the user to select a field to calculate statistics from... that is what I was referring to. From there you could emulate one of tools that I have written...
Statistics... Descriptive Statistics for Multiple fields or the older
Field Statistics
For individual statistical values, a checkbox would be simpler so they could select one or more stats parameters to calculate, then you have a simple boolean check to see what has been selected.
