Hello,
I would like to dissolve or merge records by the street name AND have separate records if there is an address gap. For example:
Input Table: (street name, low, high)
3rd Street 100-199
3rd Street 200-299
3rd Street 300-399
3rd Street 500-599
3rd Street 600-699
5th Street 600-699
5th Street 800-899
Desired Output:
3rd Street 100-399
3rd Street 500-699
5th Street 600-699
5th Street 800-899
Currently I can use Dissolve and use add the statistics for Min of low and Max of high which will create a simple dissolve, however I would like to find where there are gaps in the address.
Current (undesired results) using dissolve and statistics fields
3rd Street 100-599
5th Street 600-899
Questions:
Is it possible in ArcGIS, or Excel, or anything else to dissolve records together, but only if there is no gap in an address range? please note: I will need to know how to do this within the table view as I will be comparing a spatial dataset to a non spatial dataset.
Thanks
