Error: Error #1502: El tiempo de ejecución del script ha superado el tiempo de espera predeterminado de 15 segundos. at com.esri.ags.components.supportClasses::DoubleField/format() at com.esri.ags.components.supportClasses::DoubleField/set data() at com.esri.ags.components.supportClasses::DoubleField() at com.esri.ags.components::AttributeInspector/createFormItemComponent() at com.esri.ags.components.supportClasses::FormField/getRendererInstance() at com.esri.ags.skins.supportClasses::AttributeInspectorRenderer/commitProperties() at mx.core::UIComponent/validateProperties() at spark.components::Group/validateProperties() at mx.managers::LayoutManager/validateProperties() at mx.managers::LayoutManager/doPhasedInstantiation() at mx.managers::LayoutManager/doPhasedInstantiationCallback()
I think this was fixed in the 3.4 release that went public today. Could you download the 3.4 version and try?
The problem occurs when you select an item that has fields of type double, probably because the decimal separator in Spanish is the comma (,) instead of the dot (.).
