Is there a tool or predefined workflow to move a custom widget from Web app builder to my JS API app?
Thanks, Joe
Hi Joe,
I do not believe it is possible to move a custom widget from Web AppBuilder to an ArcGIS API for JavaScript application. The file structures of the two products are very different. Here are some helpful resources for you:
Widget Development (guide doc)
https://developers.arcgis.com/javascript/latest/guide/custom-widget/
Building Your Own Widget - Esri Dev Summit 2019
https://www.youtube.com/watch?v=YMmBsEanUws&list=PLaPDDLTCmy4Y0GMTl0O4V6LF3EmxIAivv&index=154&t=0s
Customizing Widgets - Esri Dev Summit 2019
https://www.youtube.com/watch?v=IdX7qI1oLUs&list=PLaPDDLTCmy4Y0GMTl0O4V6LF3EmxIAivv&index=155&t=0s
-Noah
All I have is a layer toggle widget that I want to bring over. Any ideas on how to recreate this?
It's difficult to say without knowing the actual code involved. Perhaps something like just toggling visibility?
Examples: https://developers.arcgis.com/javascript/latest/sample-code/?search=toggle
Its the toggle based off Robert's Code. I'll attach my WAB code from the widget.js file. Hopefully this helps
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">'dojo/_base/declare'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/_base/lang'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/_base/array'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/BaseWidget'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/LayerStructure'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/WidgetManager'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/query'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/dom-class'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/dom'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dijit/registry'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/_base/html'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/topic'</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> declare<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">,</SPAN> array<SPAN class="punctuation token">,</SPAN> BaseWidget<SPAN class="punctuation token">,</SPAN> LayerStructure<SPAN class="punctuation token">,</SPAN> WidgetManager<SPAN class="punctuation token">,</SPAN> query<SPAN class="punctuation token">,</SPAN> domClass<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> registry<SPAN class="punctuation token">,</SPAN> html <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> clazz <SPAN class="operator token">=</SPAN> <SPAN class="token function">declare</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>BaseWidget<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'LayerToggleButton'</SPAN><SPAN class="punctuation token">,</SPAN> baseClass<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'widget-layertogglebutton'</SPAN><SPAN class="punctuation token">,</SPAN> isToggling<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> layerStructure<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> toggleLayerIds<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> parentContainer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> originalTitle<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> isExclusive<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> zoomToLayer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> startup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">inherited</SPAN><SPAN class="punctuation token">(</SPAN>arguments<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerStructure <SPAN class="operator token">=</SPAN> LayerStructure<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setToggleLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> toggleBtnArr <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div[data-widget-name='LayerToggleButton']"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> toggleBtnArr<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>node<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> parentWid <SPAN class="operator token">=</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getAttr</SPAN><SPAN class="punctuation token">(</SPAN>node<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'widgetId'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> chkTitle<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>parentWid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> parentSid <SPAN class="operator token">=</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getAttr</SPAN><SPAN class="punctuation token">(</SPAN>node<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'settingId'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>parentSid <SPAN class="operator token">===</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>parentContainer <SPAN class="operator token">=</SPAN> node<SPAN class="punctuation token">;</SPAN> chkTitle <SPAN class="operator token">=</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getAttr</SPAN><SPAN class="punctuation token">(</SPAN>node<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'title'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originalTitle <SPAN class="operator token">=</SPAN> chkTitle<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/(\: Off)|(\: On)/</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> widg <SPAN class="operator token">=</SPAN> registry<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN>parentWid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>widg <SPAN class="operator token">&&</SPAN> widg<SPAN class="punctuation token">.</SPAN>widget <SPAN class="operator token">&&</SPAN> widg<SPAN class="punctuation token">.</SPAN>widget<SPAN class="punctuation token">.</SPAN>config <SPAN class="operator token">===</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>parentContainer <SPAN class="operator token">=</SPAN> node<SPAN class="punctuation token">;</SPAN> chkTitle <SPAN class="operator token">=</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getAttr</SPAN><SPAN class="punctuation token">(</SPAN>node<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'title'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originalTitle <SPAN class="operator token">=</SPAN> chkTitle<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/(\: Off)|(\: On)/</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> setToggleLayer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>toggleLayerIds <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> Object<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getOwnPropertyNames</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">.</SPAN>layerOptions<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>val<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hasOwnProperty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"zoomTo"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>zoomToLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">.</SPAN>zoomTo<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>zoomToLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hasOwnProperty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"isExclusive"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>isExclusive <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">.</SPAN>isExclusive<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>isExclusive <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">.</SPAN>layerOptions<SPAN class="punctuation token">[</SPAN>val<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>display<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>toggleLayerIds<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>val<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> onOpen<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setToggleLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> lObjs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>toggleLayerIds<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>id<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> lyrNode <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerStructure<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getNodeById</SPAN><SPAN class="punctuation token">(</SPAN>id<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//lyrNode.on('toggle-change', this.setCheckedState(lyrNode));</SPAN> lObjs<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>lyrNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>isToggling<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>isToggling <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toggleLayer</SPAN><SPAN class="punctuation token">(</SPAN>lObjs<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>isToggling <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> WidgetManager<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">closeWidget</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>lObjs<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">isToggledOn</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>parentContainer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"jimu-state-selected"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">remove</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>parentContainer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"jimu-state-selected"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">300</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> setCheckedState<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>_layerInfo <SPAN class="operator token">&&</SPAN> evt<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>layerObject <SPAN class="operator token">&&</SPAN> <SPAN class="operator token">!</SPAN>evt<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>_visible<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> topic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">publish</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'toggleChanged'</SPAN><SPAN class="punctuation token">,</SPAN> evt<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>_visible<SPAN class="punctuation token">,</SPAN> evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> toggleLayer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>lObjs<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>lObjs<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">isToggledOn</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>isExclusive<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerStructure<SPAN class="punctuation token">.</SPAN><SPAN class="token function">traversal</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>layerNode<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> layerNode<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">var</SPAN> onOff<SPAN class="punctuation token">;</SPAN> array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN>lObjs<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>lObj<SPAN class="punctuation token">,</SPAN> index<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> onOff <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>lObj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isToggledOn</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="string token">'On'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Off'</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>parentContainer <SPAN class="operator token">&&</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originalTitle<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttr</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>parentContainer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'title'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originalTitle <SPAN class="operator token">+</SPAN> <SPAN class="string token">': '</SPAN> <SPAN class="operator token">+</SPAN> onOff<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>onOff <SPAN class="operator token">===</SPAN> <SPAN class="string token">'Off'</SPAN> <SPAN class="operator token">&&</SPAN> index <SPAN class="operator token">===</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="operator token">&&</SPAN> lObj<SPAN class="punctuation token">.</SPAN>_layerInfo <SPAN class="operator token">&&</SPAN> lObj<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>layerObject <SPAN class="operator token">&&</SPAN> lObj<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>zoomToLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>lObj<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1.2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> topic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">publish</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'toggleChanged'</SPAN><SPAN class="punctuation token">,</SPAN> lObj<SPAN class="punctuation token">.</SPAN>_layerInfo<SPAN class="punctuation token">.</SPAN>_visible<SPAN class="punctuation token">,</SPAN> lObj<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> lObj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toggle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>lObj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isVisible</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN> lObj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isToggledOn</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> lObj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> clazz<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Joe,
As Noah mentioned all the widget is doing is toggling a layer visibility on or off, just like the sample he provided does for a JS API app.
