function mapReady(map){ dojo.connect(map,"onClick",executeIdentifyTask); //create identify tasks and setup parameters identifyTaskCombined = new esri.tasks.IdentifyTask("http://server/ArcGIS/rest/services/combined/MapServer/"); identifyTaskReps = new esri.tasks.IdentifyTask("http://server/ArcGIS/rest/services/IndivTerritoriesOnly/SalesReps_simple/MapServer/"); identifyParamsCombined = new esri.tasks.IdentifyParameters(); identifyParamsCombined.tolerance = 7; identifyParamsCombined.returnGeometry = true; identifyParamsCombined.layerIds = [7,8,9]; identifyParamsCombined.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; identifyParamsCombined.width = map.width; identifyParamsCombined.height = map.height; identifyParamsReps = new esri.tasks.IdentifyParameters(); identifyParamsReps.tolerance = 15; identifyParamsReps.returnGeometry = true; identifyParamsReps.layerIds = [0]; identifyParamsReps.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; identifyParamsReps.width = map.width; identifyParamsReps.height = map.height; //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }; function executeIdentifyTask(evt){ identifyParamsReps.geometry = evt.mapPoint; identifyParamsReps.mapExtent = map.extent; var deferred = identifyTaskReps.execute(identifyParamsReps); deferred.addCallback(function(response){ if (response.length > 0) { // console.log(response.length) // response is an array of identify result objects // Let's return an array of features. return dojo.map(response, function(result){ var feature = result.feature; feature.attributes.layerName = result.layerName; var template = new esri.InfoTemplate("", "${NAME} <br/> Rep #: ${rep_no} <br/> YTD Net Sales: $ ${YTD_Netsales} <br/> Presidents Club: ${PCText} <br/> Leadership: ${Ldr_type}"); feature.setInfoTemplate(template); return feature; }); } else { identifyParamsCombined.geometry = evt.mapPoint; identifyParamsCombined.mapExtent = map.extent; var deferred = identifyTaskCombined.execute(identifyParamsCombined); deferred.addCallback(function(response){ // response is an array of identify result objects // Let's return an array of features. return dojo.map(response, function(result){ var feature = result.feature; feature.attributes.layerName = result.layerName; switch (result.layerName) { case 'Zip Codes': var template = new esri.InfoTemplate("", "${ZipText} <br/> City: ${Name}<br/> State: ${State}"); //booger feature.setInfoTemplate(template); break; case 'Districts': var template = new esri.InfoTemplate("", "District: ${new_dist} <br/> District Name: ${new_distname}"); feature.setInfoTemplate(template); break; case 'Divisions': var template = new esri.InfoTemplate("", "Division: ${new_divcode}"); feature.setInfoTemplate(template); break; }; return feature; }); }); }; map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); }); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); };
dbecker88, I followed an URL on the gis.stackexchange website you quoted - http://jsfiddle.net/blordcastillo/mULcz/ - to be specific. The code was easily adaptable to my needs!Thanks,Luci
