Why does the attribute name fields change after performing an intersect?
Are you sure that when you tried to run the tool, your data was not joined to a dataset?
This causes the output field names to come out as: dataset_Fields
Which then gets truncated to dataset_
So one of your datasets in the join was called geocoding?
Thanks all. I basically uninstall/reinstall ESRI and somehow it worked. My IT team indicated that there was something going on with the malware. Thanks!
shape file
What type of output are you writing to? A shapefile? File Geodatabase Feature Class?
I'm sure. It appears the new name is of a subset of the original name that was created after I geocoded the original file. I'm sure I just confused you there.
Synopsis: I geocoded some data, then called the layer "geocoded results" (attribute table not disturbed) then I performed the intersect. This is when the attribute field names changed automatically to "geocodi_xyz (1-100)". The reason this is a problem for me...is because I am going to convert this file into an excel table and provide the data to a customer. This is a rather large dataset; encompassing over 5000 records and not a simple task of manually changing the names back. I think I may have to re-invent the wheel and perform the process all over. Thanks for your help.
the files had the same field names, you can have this since you don't want to overwrite existing data, hence the field name change based upon a minimal intrusion name outcome
Again, are you sure the new fields aren't just added fields? And they're just pushing over the older fields to the right?
Oh how I wish I could; unfortunately this data has privileged information.
Could you zip the two files you're attempting to run this 'Intersect' process on and post them here?
Thanks Mitch Muskchamp, but selecting 'ONLY FID', deleted all the data in the attribute table.
Try unslecting 'ALL' from the 'JoinAttributes' field in the 'Interset' tool window. Instead, select 'ONLY_FID'.
Are you sure it is replacing the fields and not just inserting and pushing the original fields to the right?
Let me know what happens.
It's weird. This particular intersection has changed the name of the original fields altogether. Thanks for your time.
I'm using 10.0; it adds a few fields but leaves the originals intact. Sorry, can't comment on 10.3; you may have discovered an undocumented feature, aka bug....
I am using 10.3.
Attribute table BEFORE intersect:
Attribute table AFTER intersect:
Can you provide an example? What version ArcGIS are you using?
