I am trying to add an excel table to my map. I get the message "Failed to connect to database. An underlying database error occurred. Class not registered"
What do I need to do to resolve this error?
Take a look at this article: Error: Failed to connect to database. An underlying database error occurred. Class not registered
https://community.esri.com/groups/technical-support?sr=search&searchId=dd3ef642-c507-4fb1-8c2a-e68a4b5b8e6f&searchIndex=0
Thank you.
It worked.
Juanita Owens
Administrative Committee for Pistachios
California Pistachio Research Board
4938 East Yale Avenue, Suite 102
Fresno, California 93727
Office: 559-255-6480, Ext. 101
Fax: 559 255 6485
E-Mail: juanitao@acpistachios.org<mailto:juanitao@acpistachios.org>
Please mark this as correct to help other users when they are searching for this same issue! Thanks!
I had the same problem and it worked. Although the driver is supposed to work with 2007 Microsoft Office systems, it solves the problem even if you have Microsoft Office 2016
The page appears to have moved or been dropped for "Error: Failed to connect to database. An underlying database error occurred. Class not registered". Does anybody have the new location?
Hi Robert,
The previous article does appear to have been removed. If you are receiving this error it may be an indication that the machine being used does not have Microsoft Office installed and will require a driver so that ArcGIS Desktop can view the files.
Please attempt to download the 32-bit Microsoft Access Database Engine 2010 Redistributable Driver
Download Microsoft Access Database Engine 2010 Redistributable from Official Microsoft Download Center
*The 2007 Office System Driver which was previously the solution has been deprecated by Microsoft and is no longer available for download.
Hi Jared,
My instance of MS Office was recently upgraded from MS Office 2010 (32-bit) to 2013 (64-bit). I can open .mdb and .xls files in Catalog, but I get the "Failed to connect..." error when I attempt to open. xlsx files.
I'll try the link above and let you know how it goes.
Bob
Jared,
I just tried to install the 32-bit MS Access db engine 2010 driver and I got an error that I already had 64-bit Office installed. I installed the 64-bit driver and still get the original "Failed to connect..." error when trying to open a .xlsx file.
Any ideas?
Yes, Thanks Bob! I just also downloaded the 2007 version and it worked like a charm, after attempting the newer versions that would not work due to me having 64 bit Microsfot Office products installed already.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
