You cannot perform any edits, or have the feature class participate in any geodatabase functionality (such as replication, topology, geometric networks, relationship classes, network datasets, etc). Essentially, you are getting a 'view' only feature class w/o SDE.
Is the qouted text true if I don't install ArcSDE 10.1?
Just to make sure that I understood you correctly.What you are saying is I do not need to install ArcSDE on the database server because the client contains the SDE functionality.
Another way of saying it:- I could use direct connection without ArcSDE installed for two-tier topology.- I could use ArcSDE to hide or conceal the database in a three-tier topology.am I right?
Hi,I'm trying to wrap my head around this, as I setup my test server for our upgrade.I have set up my server with Windows Server 2008 R2 sp1 and SQL Server 2012 standard edition.I have installed ArcGIS desktop 10.1 + sp1I ran through the ArcGIS for Server 10.1 sp1 installer but did not create a ArcGIS Server site. (essentially I needed the authorization file for the create enterprise geodatabase tool )I then ran the tool > 'Create Enterprise Geodatabase'I loaded some data into the geodatabase, registered as versioned.When exploring the schema all the SDE and GDB tables are present.Am I missing something? Do I need to install ArcSDE 10.1 to get the multi user/versioning/history capabilties of ArcSDE, or as this discussion indicates this is now inherent in the desktop. I still am not 100% clear why I would need to install the ArcSDE application server or command line tools.If I am managing data via desktop (ArcMap & ArcCatalog) I do not need to install anything furtherIf I am managing data via web editing tools I do need to install the ArcSDE application server.Thank you for any clarification you can provide.Fiona
Am I missing something? Do I need to install ArcSDE 10.1 to get the multi user/versioning/history capabilities of ArcSDE, or as this discussion indicates this is now inherent in the desktop.
HI All, Please help me understand this for the personal ArcSDE. For the previous item...No, you do not need to install an ArcSDE 10.1 application server to get full geodatabase functionality, including multi user/versioning/history. So can I still use a personal ArcSDE with Desktop without ArcGIS Server, say on a laptop? If so, do I need to through through the same procedure for creating or enabling a enterprise geodatabase? If, so how. The create geodatabase requires an authorization code for ArcGIS Server.ThanksBrian Kaplan
Brian, there is no "personal ArcSDE", there is just the ArcSDE DLL's that incorporate all the functionality to allow a Direct Connect connection on your local personal PC to a (remote) enterprise geodatabase, but that isn't a product called "personal ArcSDE".Additionally, if you want to create an enterprise geodatabase (so no file geodatabase), you will need an ArcGIS for Server commercial licence, as ArcSDE / ArcGIS for Server is a sale / non-free product of ESRI, and using an enterprise geodatabase requires this licence, even if you only start using it for testing purposes. That is why you are being asked for an authorization code.You may be able to get a temporary trial licence for free for testing purposes, IDK, but as soon as you start deploying it, you will surely need a true paid licence. For that, there are two possible licencing levels: "ArcGIS for Server Enterprise" and "ArcGIS for Server Workgroup", see this page:http://www.esri.com/software/arcgis/arcgisserver/features/enterprise-workgroup
Enterprise geodatabases, which run in many different flavors of RDBMS software, require anArcGIS for Server Enterprise license. Desktop (formerly known as "Personal") and Workgroup multiuser geodatabases (which only run in SQL-Server Express, and are subject to restrictions in user count, storage, RAM, and CPU cores) are available at different licensing levels. The Multiuser Geodatabase page breaks down the options. - V
Some of you here said that if I do not install ArcSDE application on the server, and use only ArcGIS for Desktop, I'll need to install an Oracle Client (32bit ofcourse) on each desktop that will direct connect to the geodatabase via ArcCatalog/ArcMap.However, I need to be able to connect to the geodatabase (direct connection or application connection) via a desktop without an Oracle client installed. For that, I'll need to install the ArcSDE application on the server, correct?Also, will I need to use application connection or a direct connection?
Please note you need to add the following line to your Windows services file of your client PC running ArcGIS for Desktop per installation instructions for the ArcSDE Application Server. Please note this has to be done on each machine connecting to your Application Server!:esri_sde 5151/tcpThe Windows services file is simply called "services" without a file extension and in Windows 7 located in:C:\Windows\System32\drivers\etc
Ariel, if you need the full geodatabase functionality but can't install the Oracle Client, than yes, your only option is to install and run an ArcSDE Application Server (which isn't a bad thing or so ).In this scenario, the connection is called an Application Server connection, so you won't be using Direct Connect.Please note you need to add the following line to your Windows services file of your client PC running ArcGIS for Desktop per installation instructions for the ArcSDE Application Server. Please note this has to be done on each machine connecting to your Application Server!:esri_sde 5151/tcpThe Windows services file is simply called "services" without a file extension and in Windows 7 located in:C:\Windows\System32\drivers\etc
I have a question though - I've heared a rumor that ESRI will probably eventually stop supporting Application Server Connection, is that true?What is the "recommended" method of connection by ESRI?
Would ArcSDE be appropriate for a single user who works on a standalone workstation?
Do you know if using ArcSDE If I would be able to connect Crystal Reports 2008 to the geodatabases directly, rather than I know have to export to a personal geodatabase?
Thank you
