import arcpy import pythonaddins import os import time class ExtensionClass1(object): """Implementation for PrintToPDF_AddIn_addin.extension2 (Extension)""" def __init__(self): # For performance considerations, please remove all unused methods in this class. self.enabled = True def openDocument(self): mxd = arcpy.mapping.MapDocument("CURRENT") mxd.activeView = "PAGE_LAYOUT" #Make sure Layout View is active arcpy.RefreshActiveView() #Refresh the view if mxd.description == 'Print to PDF': arcpy.mapping.PrintMap(mxd, r"Adobe PDF", "PAGE_LAYOUT") pass
import arcpy import pythonaddins import os import time class ExtensionClass1(object): """Implementation for PrintToPDF_AddIn_addin.extension2 (Extension)""" def __init__(self): # For performance considerations, please remove all unused methods in this class. self.enabled = True def beforeCloseDocument(self): #this works but runs before file fully opens mxd = arcpy.mapping.MapDocument("CURRENT") if mxd.description == 'Print to PDF': arcpy.mapping.PrintMap(mxd, r"Adobe PDF", "PAGE_LAYOUT") time.sleep(25) os.system('taskkill /IM Arcmap*')
What's the overall workflow? Is the user interacting with the map or are you just printing each mxd?
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
