Hello!
Does anyone know how I can speed up the process Join Space ?. On my machine it has taken too long.
This is my setup
i5 3.0 GHz
8GB RAM
thanks
We need details. Featureclasses? shapefiles? files on local disk? on network? are the files indexed? size?
or use small, indexed featureclasses stored on a local disk
The files are quite large, but I have done it before and had not taken so long.
I formatted the computer and now I'm with Win8
All files are on the PC, look at the printscreen of an example of all my files.
The idea is to cross points to polygons
Another issue is very different save files in a specific folder to save the directory: C: \ Users \ Joyce \ Documents \ ArcGIS \ Default1.gdb
See Curtis's comments in this thread regarding *.mxd's
Performance problems in desktop 10.3.1?
So 2 things. First, save to a simpler drive path...you should only use that c:\user\thingy folder for photos and junk
good luck
You have a shapefile there that has a dbf approaching the 2GB limit. This is an operating system limit!
You may want to consider putting these feature classes in a file geodatabase. They are pretty big but at least your processing is more likely work at all.
Thanks for the tips, will launch a new project this way to see if it helps.
The file is too large. I have over 4 million points to join with many polygons.
Do you think that kind of projection could influence this type of analysis (join space)?
The shapes of the polygons were reprojected to Albers. The shape with the points I make from my data, first I do it in WGS after reprojected to Albers
These are the files of properties
The Datum makes sense with the projection?
Also turn off background processing.
The open when Arcgis uses only 30% of the processor, I changed the process for priority in real time. This did not show much difference.
As for RAM, ArcGIS uses very little. Google Chrome uses a lot more.
Do you think it would be very bad open the ArcGIS three times to run different tasks? So I speed work.
thank you!
