result = [row[0] for row in arcpy.da.SearchCursor( outFC, ("RegID_6k99"))] unique = set(result) lengthDict = {} for uni in unique: where = "\"RegID_6k99\" = '%s'" % (uni) lengths = [row[0] for row in arcpy.da.SearchCursor( fc, ("Shape_Length"), where)] lengthDict[uni] = sum(lengths) for each in lengthDict.keys(): print "%s: %s" % (each, lengthDict[each])
Many thanks Mark for your reply. This has been really useful. I have been working through it and have tried to modify it slightly. I have run into some errors (see attached jpg) and I don't think it does exactly what I want it to do. I don't think I explained the task very well initially. So I will need to modify the code further but its definitely (thanks to your help) going in the right direction.
I have attached a txt file explaining what I am trying to do. Any other suggestions greatly accepted. I have been working on this for many days - nearly pulling my hair out. The task is critical to proceed. The number of records does not change but the assigned region value for each record can have an exponential amount of permutations which I need to test. Therefore automation is crucial.
Many thanks again
Lorraine
I've modified the script to include looking at the field name but I need to sort out the if else statement at the end.
Help please!!
Any comments greatly appreciated
Hi Lorraine,
Please have a look at the code below:
import arcpy fc = "C:/Temp/lorraine/NIData.gdb/fc_f6000_in99Matx" fld_id = "RegID_6k99" fld_label = "FLABEL" fld_flows = "RegIntFlows" # create a unique list of all the FLABEL values lst_labels = list(set([row[0] for row in arcpy.da.SearchCursor(fc, (fld_label))])) # Create the list of fields to be used in the SearchCursor flds = [fld_id, fld_label] flds.extent(lst_labels) # create list of all fields flds_all = arcpy.ListFields(fc) # make sure that the relevant fields for the SearchCursor exist in fc flds = list(set(flds) & set(flds_all)) # loop through data and fill the result dictionary dct_res = {} with arcpy.da.SearchCursor(fc, flds) as curs: for row in curs: uni_id = row[flds.index(fld_id)] lbl = row[flds.index(fld_label)] if lbl in flds: val = row[flds.index(lbl)] if uni_id in dct_res: dct_rec[uni_id] += val else: dct_rec[uni_id] = val else: # lbl in field FLABEL does not exist as field pass # now update the values with an update cursor and the result dictionary flds = (fld_id, fld_flows) with arcpy.da.UpdateCursor(fc, flds) as curs: for row in curs: row[1] = dct_res[row[0]] row.updateRow(row)
First of all I have not tested the code, so this might not work at all. If you are willing to attach a part of your data to this thread, I could test the code and tweak it where necessary...
I'll try to explain what I intent to do in the code:
I hope this makes sense to you and that the code actually runs. If not, please let me know and I see what I can do.
Kind regards,
Xander
@XanderBakker, thank you so much for taking the time and effort to look at this, this is really helpful. I was completely stuck with it. You are brilliant. The code sounds as if it will do exactly as I want it to do.
I've tried running the code but I get an error with the list and update cursor. Any ideas?
I have zipped up feature class and attached it here. If you could take a look that would be great.
Many thanks Xander
Thanks for sending the dataset. This way I could test the code and noticed that I had quite a number of errors in the script.
Please observe the corrected code that "did something" (you should verify if the values correspond to what you expected).
import arcpy # fc = "D:/Xander/tmp/NIData.gdb/test_copy" fc = "C:/Temp/lorraine/NIData.gdb/fc_f6000_in99Matx" fld_id = "RegID_6k99" fld_label = "FLABEL" fld_flows = "RegIntFlows" # create a unique list of all the FLABEL values lst_labels = list(set([row[0] for row in arcpy.da.SearchCursor(fc, (fld_label))])) # Create the list of fields to be used in the SearchCursor flds = [fld_id, fld_label] flds.extend(lst_labels) # create list of all fields flds_all = [fld.name for fld in arcpy.ListFields(fc)] # make sure that the relevant fields for the SearchCursor exist in fc flds = list(set(flds) & set(flds_all)) # loop through data and fill the result dictionary dct_res = {} with arcpy.da.SearchCursor(fc, flds) as curs: for row in curs: uni_id = row[flds.index(fld_id)] lbl = row[flds.index(fld_label)] if lbl in flds: val = row[flds.index(lbl)] if uni_id in dct_res: dct_res[uni_id] += val else: dct_res[uni_id] = val else: # lbl in field FLABEL does not exist as field pass # now update the values with an update cursor and the result dictionary flds = (fld_id, fld_flows) with arcpy.da.UpdateCursor(fc, flds) as curs: for row in curs: row[1] = dct_res[row[0]] curs.updateRow(row)
Some of the errors in the code where:
At least I learned a thing that I shouldn't try to do these kind of things without a dataset...
Hope this works for you.
Xander, thank you so much. I knew I was missing the ability to get the values from the cursor, just didn't know how to go about it.
I have run the code on data. The intended field (TotRegFlows) is being updated but I am not sure how the figure is calculated. Each row (or Ward) should have a unique total. By running the code, all rows with the same RegID_6k99 value has the same. I have calculated the correct totals manually for two RegID_6k99 values. I have attached a screendump of one example where RegID_6k99 = 4. In the example there are 3 wards with a region ID of 4. the FLABELs of these wards are F95XX01, F95XX10, F95XX11. Correct flow totals are shown in the attached screendump.
The values from running the code for these three rows or wards are all 962. I can't spot where this value is coming from.
Do you think the error could be related to the sorting of fields? Should include a print somewhere along the way to check expected values?
Xander, thanks for your help, I really appreciate it
What I understood is that the code should sum the values for all records for a RegID_6k99. That's why the result is higher than you expected. Based on what you are showing, it seems that the calculation should be affected for each row. This means that there is no need to have both the Search cursor and the Update cursor. A single Update cursor will do.
Before I start with the changes in the code, let me get some things clear:
If this is the case we will need to create an initial dictionary that stores the 1:n relation of RegID_6k99 and FLABEL. In the update cursor we will need to read this dictionary to determine which fields to sum.
If this is what you are looking for, let me know and I'll dive into that.
Try this code, it creates the same value you are expecting:
import arcpy # fc = "D:/Xander/tmp/NIData.gdb/test_copy" fc = "C:/Temp/lorraine/NIData.gdb/fc_f6000_in99Matx" fld_id = "RegID_6k99" fld_label = "FLABEL" fld_flows = "RegIntFlows" # create a unique list of all the FLABEL values lst_labels = list(set([row[0] for row in arcpy.da.SearchCursor(fc, (fld_label))])) # Create the list of fields to be used in the SearchCursor flds = [fld_id, fld_label] flds.extend(lst_labels) # create list of all fields flds_all = [fld.name for fld in arcpy.ListFields(fc)] # make sure that the relevant fields for the SearchCursor exist in fc flds = list(set(flds) & set(flds_all)) # create a dictionary with for each RegID_6k99 a list of corresponding FLABEL fields dct_ref ={} flds2 = (fld_id, fld_label) with arcpy.da.SearchCursor(fc, flds2) as curs: for row in curs: uni_id = row[0] lbl = row[1] if uni_id in dct_ref: lst_lbls = dct_ref[uni_id] if not lbl in lst_lbls: lst_lbls.append(lbl) else: lst_lbls = [lbl] dct_ref[uni_id] = lst_lbls # loop through data and fill the result dictionary flds.append(fld_flows) with arcpy.da.UpdateCursor(fc, flds) as curs: for row in curs: uni_id = row[flds.index(fld_id)] if uni_id in dct_ref: lst_lbls = dct_ref[uni_id] val = 0 for lbl in lst_lbls: if lbl in flds: val += row[flds.index(lbl)] else: print " - lbl {0} in field FLABEL for RegID_6k99 = {1} does not exist as field".format(lbl, uni_id) row[flds.index(fld_flows)] = val curs.updateRow(row) else: print "key uni_id {0} not found in dct_ref".format(uni_id)
What has changed is this:
