I guess a bit of clarification. It seems that slowly but surely more forum sections are being generated, and now they want SDE broken out, so that is what I mean by old style. Fix the search, institute better tagging. Less is more.
More posts = More activity. More activity = More people reading the threads And then they'd think that if more people are reading a specific forum = Most likely that someone will answer their questions
Okay, so let's say we did separate it out into GP Tools, GP Python, GP Model builder, and GP General? How "general" are we talking about here? What kind of questions could be left to post in the GP general category without mentioning a tool, script or model? Sounds odd�?�
I think that a forum called "other" won't attract as many posts as one called "general", as someone else mentioned a while ago.If the searching/keywords/tags could be fixed to make posts a lot easier to find, I would be all for it, I just don't see that happening 🙂
Using this logic, ESRI should then only have a single forum, as that would surely maximize/consolidate posts...
While we're at it, maybe get rid of those forums that have <= 25 threads (which BTW is about 45% OF THEM!!!). See for yourself: http://forums.arcgis.com/forums/3-ArcGIS
What we really want to do is to design and mold the organization and functionality of the forums to generate the most input, discussions, and make it easiest and most valuable to use for most users. It's not logical nor appropriate for us to ask everyone to change just for the sake of change, when that change makes everything more difficult. That would be ridiculous. But as with any system that is used by many people, we have to be careful when making changes. Every one much be checked out to make sure that changing one thing for a few doesn't make other things more difficult for most, with special emphasis on those who actually do more contributing than consuming.>most of those people do not use search engines to find any new posts that would fall into their field of expertise I would agree. I've never heard of users who do this. And I've not even done this myself with the old forums. The tool was too weak and not designed for that. I went to the very specific forums that I happened to know were there, and that in effect became a built-in query filter. That also assumes topics that should be in that specific forum are always there too, which we pretty much all know wasn't completely the case. But again, I knew the forum landscape like the back of my hand.When it comes to volunteers who provide assistance in the forums, I'm hearing from just a few so far who consider themselves experts but only in very small niche areas of the ArcGIS system. Isn't it true (and we could be wrong) that most GIS Professionals have knowledge to share and areas of interest to learn than just one extension or set of tools? With these new coarse grained categories these folks can now go to perhaps one or two forums rather than a few, or dozens, or 50, 60, etc.? From those folks we would often hear "I don't use your forums because they're too detailed. I don't know where to ask my question. ESRI tends to want to overconfuse things, like the forums." and others along those lines. I'm also not hearing what your experience has been with straddle topics and misposting. The coarse grained forums also then expose users to questions and opportunities to hear about and learn about things they might not have while focused on smaller areas (not the primary reason, but another benefit we've noticed.)That said, in a significant way I'm absolutely not disagreeing with anyone in this thread. We understand how the forums were used because we used them too, and many of us were users of ESRI stuff long before we got here to ESRI. There are a few that have said, "if I no longer have my very specific niche forum, then if I want to browse rather than search, I need to wade through lots of topics I'm not interested in". I get that. I do. But any design must be inversely analyzed too, and then implemented to fit the most common use cases. Everyone's interested in slightly different things, and not all threads are of interest to everyone, we get that too. In the end it will come down to data that we pull out of the system. If they get more users, more views, more queries, more time spent around the site, answered more, queried more, then that will confirm what we're all doing. Else it won't and we'll need to modify things immediately and as we go in order to keep this tool valuable for everyone, especially for the contributors.
Totally agree with Sean's earlier post. If your field of knowledge is in certain areas it is alot more difficult now to reply to posts and find answers too. For this one reason I have helped alot less people since the switch over.
I think many would agree with that to some point. Even for most of us here at Esri it would be tough to argue against that from that perspective. If we had forums clearly labeled and organized by fine-grained topics like "Topology", it might make it easier for people with Topology questions to ask them, and definitely easier for people expert with topology to answer them. Just a few things I can toss in to help explain why we didn't do it that way this time:a. With the old forums, we did have those very fine-grained topics. But that led to there being almost 400 of them. It's not reasonable to expect that users should sift through forums to become familiar with what's there and what's not when there are that many. We received many complaints about this over the years. And that's not counting how many users perhaps didn't complain because they were too overwhelmed and just didn't use them and never came back. And the usage data is clear that many just posted into the nearest "...-General" forum they could find so that they didn't have to hunt and peck for a specific forum that may or may not be there. You might "think" all of the topology issues are in the topology forum, but they're not. We had to find a middle ground between users who don't know and experts who do know. b. Some users with an issue that relates to the concept of Topology might not know that term yet. Or maybe they do but don't know that the solution to their problem involves Topology.c. If you know your issue or question relates to topology and you want to search for it before posting, if you're good with keywords and you understand what you're looking for, the search will find it, cutting across all of the forums. That includes the product-based "Products" forums and the more workflow-based "Functions" forums.d. Many issues using ArcGIS are more general and broad than specific categories can encompass. This causes a lot of cross-posting, misposting, and users saying "I'm using ArcGIS, where does my question go?".So, between the search tool, broad issues, users not fully understanding the nature or solution to their problem (which is why they're here asking on the forums), seems we're better off with more general categories than specific ones. Seems to be working well so far. Well, except for Extensions, which is why we ended up splitting those back out.
Another trade off. What we found is that the almost 400 fine-grained specific categories in the old forums were more difficult to learn and use than necessary. And frequent mis-posting provided an illusion that each category contained all relevant discussions when that was often enough not the case. Not to mention topics that straddled two or more of the fine-grained categories. We found that users would rather rely on a good search engine (both from inside or from outside our site) to find information then by learning a complex site layout and trying to navigate to it. The categories still have enough granularity to support groups of users with similar interests.Perfect? No. But dealt a set of cards, we're playing the strongest ones based on user requests and usability testing.
I agree, Goh_Raj, that Jim is a very smart person who has a lot of good stuff on the forums to refer back to, and has a lot of reference for designing the forums, he has A LOT of experience with these forums.Father knows best. Less is more.I Second the better search capability, again...
Ted, what happened to:"...it would be nice to have the capability to just have access to the 1 python forum...""...which why I am thinking, a python category makes sense."Seems like "Python Scripting" is an important "Function" and is becoming more so for many of us...
The more capability we see with python, the more sense to me, that it has its own category. Python is not just GP tools, it has its own window now, which may be using tools, but I think python has moved a bit past just GP. Less is more, is just that, maybe I should just say, Simple is better than complex, Sparse is better than dense... Python itself could easily have more than one category, but for this I say Less is more.
I'm playing with Arcpy.Mapping now and with all the new goodies in arcpy, yes Python could definitely have more than one category. I don't know why, but I am currently thinking about the non-python users right now... I keep thinking: If we have a separate python forum, do you think non-python users can just take a peek at what we are all talking about? Would they even venture there or would they just stick to playing with tools and models? I feel they might miss something, like miss a discussion that provided a much easier solution to their problems via python, and thus miss a chance to get them over to the sunnier side of GP. Heck, if I were a non-Python user and read about the great things that other users are doing with arcpy.mapping, that alone would get me curious. That is the same with anything else in Python (insert cool python stuff here) and it might trigger a "Hey I think that would help our organization too" or "Wow, you can do that in Python, let me check that out!" I see positives and negatives for keeping GP together or splitting it up, so what happens now?
Besides the new thread ultimately becomes a KB for Python, for User Python examples that solve real world issues
So if I rephrased the title of this thread to be:"Should there be a new Python Scripting forum?"Would you guys (Ted, Goh_Raj, Chris Mathers) go that way? It sounds so far like a shaky "yes", but I want to be sure. I'd poke Dan P. too, but I know he has taken an oath of silence...
Jim -Perhaps you can now unstick this thread so it slowly dies away.
