Simon, I used your xml you provided and searched for "Weaver lake Elem" and the reservation for that school came up fine.
Simon, Try downloading again. I updated the zip to ensure the correct number of assets in each folder.I will add attachment support to the wish list, although I am getting concerned that this widget does to much (the main mxml is nearly 4000 lines of code. and has 22 supporting files).
Simon, Care to provide a specific example I can using in the testing?
Does anybody know why I might only have the graphical search tool as a selection method while the others including show datagrid disappear. Is it that something that automatically occurs with the data type or geometry server. I did not disable the buttons in the xml. The icons are in the assets folder. The graphical search seems to work. Version 2.4.0.14Flex 4.5.1flash player 10.2agslib-2.4-2011-07-25Thanks,Eric
James, No that is actually why it is called fixed datagrid.
Simon, You should win a prize for this. Some how you choose the one programmatic path that I missed a step in. Because you were using a layer with multiple relates and you did not define specific return fields for any of the relates the oid was not getting passed to the query... Anyway I have it fixed and will get it released ASAP. Thanks for using my new feature and helping me fine tune it.Version 2.5.0.4 - 12/7/2011* Fixed a relate query error that only occurred in certain situations
