I have an application in WAB that is working really well. However, a couple of users pointed out that when you perform an identify on the map close to a point, the following message appears:
Can I disable this message somewhere in the .js or config files?
Also, to activate the popup is there a way to increase the tolerance when the popup is used in mobile? It appears you have to be exactly on the point to get the popup to appear, meaning a user might have to tap several times for the popup to appear for a feature.
The No Information popup might be misleading to a person that thinks they are clicking on a feature, but no results are returned.
Any suggestions?. Thank you!
Ian
