When I just use this, the field does not populate at all. <value prompt="Lease Status: [ Auto Populate ]" isvaluerequired = "false" uniquevalsfromfield="LeaseStatu" operator="AND">LeaseStatu = '[value]'</value>
Matt, Is the service in question public? I have not seen what you are talking about using my services or esri public ones.
Robert,Thanks for your quick reply.When I say auto-populate, the drop down selection box is populated with values that are contained in that field. It seems that the issue is intermittent as it works sometimes, but other times nothing is populated in the box and it is blank.Here is an example of it working. Permitted, Producing, Proposed are all be populated from a Geodatabase.[ATTACH=CONFIG]22351[/ATTACH]Next time I run the SFV, I might just get blanks.Thank you,Matt
