Ok I think I’m close but need a little more help. I have atable like the one attached. I’m trying to create a line segment from itthat goes from 22.473 to 27.346 but they are on separate lines. I need apython script to calculate the to_measure from OBJECTID 1 equal to theto_measure from OBJECTID2. Do you think that is possible?
You can iterate through each RID and update the to_MEAS field. Ex:
table = "Sample" ridList = [] with arcpy.da.SearchCursor(table, ["RID"]) as cursor: for row in cursor: ridList.append(row[0]) del cursor ridList = set(ridList) for RID in ridList: toMeasList = [] with arcpy.da.SearchCursor(table, ["RID", "to_MEAS"], "RID = '" + RID + "' ") as cursor: for row in cursor: toMeasList.append(row[1]) del cursor toMeasList.sort() with arcpy.da.UpdateCursor(table, ["to_MEAS"], "RID = '" + RID + "'") as cursor: for row in cursor: row[0] = toMeasList[-1] cursor.updateRow(row) del cursor
I get a 000539 : Error message from Python. It seems like it should work. At the end its taking the row[0] array and setting the toMeasList equal to it minus 1 record correct?
Says syntax error line 1 which is declaring the table correct?
Yes, you will need to update the 'table' variable with the feature class/table in the Table of Contents. Ex:
table = 'RoutingTable'
I did that, the table is called result. Does it have to be a certain type of table?
Can you zip and upload the table you are using?
I created sever types of table and set the table variable but seems to keep throwing the syntax at line 1. Here is an example of an exported table and the code I used.
table = "Export_Output" ridList = [] with arcpy.da.SearchCursor(table, ["RID"]) as cursor: for row in cursor: ridList.append(row[0]) del cursor ridList = set(ridList) for RID in ridList: toMeasList = [] with arcpy.da.SearchCursor(table, ["RID", "to_MEAS"], "RID = '" + RID + "'") as cursor: for row in cursor: toMeasList.append(row[1]) del cursor toMeasList.sort() with arcpy.da.UpdateCursor(table, ["to_MEAS"], "RID = '" + RID + "'") as cursor: for row in cursor: row[0] = toMeasList[-1] cursor.updateRow(row) del cursor
This is an image of the errors I receive in ArcMap
I'm jumping into this thread midstream, but I'm confused why this has anything to do with Calculate Field. You're running this in the Python window, not the field calculator, correct?
In any case, it looks like however you are calling CalculateField, it is set to VB not Python.
I’m trying to calculate a field based on another field in a table using python in the field Calculator.
The last line in the error message indicates that the Field Calculator was run in VB mode:
del cursor" VB #
That is my fault I copied the wrong results.. I get an invalid syntax when I select python..
Terry,
The code I provided was written to be run in the python window. Attached is an example. Here are the steps to take:
1. Add the 'sample' table to ArcMap
2. Open the Python window
3. Open 'script1.py' in a text editor
4. Copy the syntax
5. Paste into the Python window and click Enter a couple of times to execute the code
The 'sample' table should be updated successfully.
Ok, that does work, I was trying to run the python code via the Field calculator. Is that possible? The reason I wanted to do that was I’m building a model to run a process and the second to the last step is to populate the to_MEAS so I can create a line segment.
It may be easier to add the script to the model. The only thing you would need to change in the script is the 'table' variable. You would need to set this to the full path to where the table is. Ex:
table = r"C:\data\sample.dbf"
