I am having the same problem with my feature service map. The public can't open it despite making it public. Any help?
Hi Baffour,
If your users are being prompted to login, check to ensure that the web map and all of the layers in the map have been shared with everyone. If this is the case, and you are sharing a web map via your organizations url, ensure that anonymous access is enabled, or modify the ult to come from www.arcgis.com.
-Kelly
Baffour,
A lot has changed since I first created this discussion. I have not had any issues sharing ArcGIS Online web maps or apps in recent years. Make sure the ArcGIS online "web map" is shared with Everyone (public). Make sure all the layers added into the web map are shared with Everyone (Public). If any layers added into the web map are "not" shared with the public, this could possibly be your issue. When you save the ArcGIS online web map, you may be prompted with an "Update Sharing" popup screen for layers that are not shared the same way. Just click on the "Update Sharing" button. If you click on the "Cancel" button the layers in the web map may not be visible.
A simple test: Log in and open the web map. Click on the "Share" button.... When the Share pop-up window appears: First make sure the Everyone (public) check box is checked ON. If "Yes". Then copy and paste the "Link to this map" URL into a new browser window and open it. (Note: Clear your browser cache if you are logged in to ArcGIS Online. Otherwise the web map will open and you will probably be logged into AGOL). The web map should open and you should see a "Modify Map / Sign In" in the upper right hand corner of the web map. If this fails you may want to consider contacting ESRI Tech support.
Hope this helps you out.
Mike Semenek
Oh, there is one thing I didn't say here; the service is from SQL Database.
Hey Baffour,
If the layer is hosted on a local ArcGIS Server then sharing the layer won't resolve the issue. Look into how you are sharing the web map and anonymous access. Feel free to share the link on this post and we can see if there are any hints as to what is causing the issue.
I have well over 80 services setup that point to are SQL databases for data. Some secured, some open to the public.
Additional questions I would be asking you are:
Do you have an ArcGIS Server?
Do you have an ArcGIS Server with rest services open to the public?
Did you setup token security on your ArcGIS Server?
Is the rest service secured? If "Yes". Did you add the rest services into AGOL from your ArcGIS Server? If "Yes". Did you save the user account and password to open the layer up in an AGOL web map. (So users do not need to log into ArcGIS Online and then log into the ArcGIS Server rest services to open up the secured data.)
If you added the data directly in from your rest services (and the service is secured on your ArcGIS Server) you will always be prompted with a login screen.
I do recommend you contact ESRI support. Why?? Because this discussion can lead into several other issues you might be having.
Mike
Hi Kelly and Michael,
I added more service to the portal but whiles all (except one) were able
to open without logging, the main one ( Registreringsplantefelter2)
appeared for some few seconds on the content list and then vanish. Below
is the link:
http://fylkesmannen.maps.arcgis.com/apps/webappviewer/index.html?id=016ab3d6c76f4e9cad75b3498202f036
Sorry the services are in Norwegian .
Baffour
Thanks Baffour,
It looks like one of the layers in this app is pointing to an internal service:
https://nygeoserver:6443/arcgis/rest/services/PlantingskogKlimatiltak/Registreringplantearealer2/FeatureServer/0
Replace this layer with one that is exposed to the internet in order for public users to be able to see it.
Do you have an ArcGIS Server? YES
Do you have an ArcGIS Server with rest services open to the public? YES
Did you setup token security on your ArcGIS Server? YES
Is the rest service secured? If "Yes". Did you add the rest services into AGOL from your ArcGIS Server? If "Yes". Did you save the user account and password to open the layer up in an AGOL web map. (So users do not need to log into ArcGIS Online and then log into the ArcGIS Server rest services to open up the secured data.) YE
'Pointing to an internal service' Please Kelly can you explain further?
The service that you are pointing to is a url that you can only access on your network. It is the internal address to your service. If you modify your app/ web map to use this url: https://nordlandsatlas.no/arcgis/rest/services/PlantingskogKlimatiltak/Registreringplantearealer2/FeatureServer/0 , it has been exposed to the internet and public users will be able to use it.
Resurfacing this thread with similar issue on AGOL.
If I create a Web Mapping application from the Map Viewer with Simple Viewer template, when shared the user is redirected to login page:
https://uni-lj.maps.arcgis.com/apps/View/index.html?appid=5ae7930aae04460fb13bf16d6d720a31
Using the same Web Map and procedure but with Minimalist template, the user has no problem accessing the web app:
https://uni-lj.maps.arcgis.com/apps/Minimalist/index.html?appid=e07d276afe6a4bd081121e8c4b8bc976
The map itself can also be accessed:
https://www.arcgis.com/home/webmap/viewer.html?webmap=58783708bc0d461da104b8ce138b1a52&extent=13.4545,45.2293,15.4828,46.1473
Could there be a widget in the Simple Viewer causing the bug?
(I'm testing on Chrome in Incognito tabs)
I had the same issue in the Information Lookup template. The web app is embedded in our website as an iframe and there's also a hyperlink to it on the same page. The embedded iframe works with no problems, everything is shared publicly, no sign in required. When clicking the hyperlink, however, the app would open in another tab, and require a sign in. I opened the web map itself to test it and there were no issues opening it that way; something in the wep app template was forcing the sign in.
It finally worked after I went to configure the Information Lookup application we created and unchecked the 'Show the basemap selector' under Options. Now the hyperlink works on the website and does not require a sign in. When this option was checked, the basemap selector worked fine in the embedded iframe, but not with the hyperlink.
I hope this helps others.
This was precisely where I was stuck as well. Thank You! ... Thank You! ... Thank You!
