import sys var =gp.GetParameterAsText(0) if var not in ("cat","dog","mouse"): print "ERROR: You entered the wrong animal! Exiting script..."; sys.exit() else: print var + " is a valid entry. Good job!"
if animal == "dog": pass #aka don't do anything else: print "not a dog"
for x in (1,2,3,4,5): if x > 4: break #aka stop looping else: print x
This did not work for me. I had a loop running a selection and writing values to a text file and cancel would only effectively cancel the current selection. I tried cancel about 10 times before calling it quits. One thing that will always work is "End Process" in the task manager but that is probably not recommended.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
