# -*- coding: utf-8 -*- # --------------------------------------------------------------------------- # a.py # Created on: 2013-01-21 15:09:24.00000 # (generated by ArcGIS/ModelBuilder) # Description: # --------------------------------------------------------------------------- # Import arcpy module import arcpy # Local variables: WELLS__2_ = "C:\\FoB Oil and Gas\\GoM\\GOM_Spatial.mdb\\WELLS" WELLS__3_ = "C:\\FoB Oil and Gas\\GoM\\GOM_Spatial.mdb\\WELLS" WELLS__4_ = "C:\\FoB Oil and Gas\\GoM\\3_Compare\\Compare.mdb\\WELLS" WELLS_Layer = "WELLS_Layer" # Process: Make XY Event Layer arcpy.MakeXYEventLayer_management(WELLS__4_, "SURFACE_LONGITUDE", "SURFACE_LATITUDE", WELLS_Layer, "GEOGCS['GCS_North_American_1927',DATUM['D_North_American_1927',SPHEROID['Clarke_1866',6378206.4,294.9786982]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98305509728916E-09;0.001;0.001;IsHighPrecision", "") # Process: Feature Class to Feature Class arcpy.FeatureClassToFeatureClass_conversion(WELLS_Layer, WELLS__3_, "Wells_Spatial", "", "API \"API\" true true false 12 Text 0 0 ,First,#,,API,-1,-1;WELL_NAME \"WELL_NAME\" true true false 255 Text 0 0 ,First,#,,WELL_NAME,-1,-1;WELL_NAME_SUFFIX \"WELL_NAME_SUFFIX\" true true false 8 Text 0 0 ,First,#,,WELL_NAME_SUFFIX,-1,-1;OPERATOR \"OPERATOR\" true true false 75 Text 0 0 ,First,#,,OPERATOR,-1,-1;BOTTOM_FIELD_NAME_CODE \"BOTTOM_FIELD_NAME_CODE\" true true false 8 Text 0 0 ,First,#,,BOTTOM_FIELD_NAME_CODE,-1,-1;SPUD_DATE \"SPUD_DATE\" true true false 255 Text 0 0 ,First,#,,SPUD_DATE,-1,-1;BOTTOM_LEASE_NUMBER \"BOTTOM_LEASE_NUMBER\" true true false 10 Text 0 0 ,First,#,,BOTTOM_LEASE_NUMBER,-1,-1;RKB_ELEVATION \"RKB_ELEVATION\" true true false 8 Double 0 0 ,First,#,,RKB_ELEVATION,-1,-1;BH_TOTAL_MD \"BH_TOTAL_MD\" true true false 8 Double 0 0 ,First,#,,BH_TOTAL_MD,-1,-1;TVD \"TVD\" true true false 8 Double 0 0 ,First,#,,TVD,-1,-1;SURFACE_NS_DISTANCE \"SURFACE_NS_DISTANCE\" true true false 8 Double 0 0 ,First,#,,SURFACE_NS_DISTANCE,-1,-1;SURFACE_NS_CODE \"SURFACE_NS_CODE\" true true false 1 Text 0 0 ,First,#,,SURFACE_NS_CODE,-1,-1;SURFACE_EW_DISTANCE \"SURFACE_EW_DISTANCE\" true true false 8 Double 0 0 ,First,#,,SURFACE_EW_DISTANCE,-1,-1;SURFACE_EW_CODE \"SURFACE_EW_CODE\" true true false 1 Text 0 0 ,First,#,,SURFACE_EW_CODE,-1,-1;SURFACE_BLOCK_NAME \"SURFACE_BLOCK_NAME\" true true false 255 Text 0 0 ,First,#,,SURFACE_BLOCK_NAME,-1,-1;BOTTOM_NS_DISTANCE \"BOTTOM_NS_DISTANCE\" true true false 8 Double 0 0 ,First,#,,BOTTOM_NS_DISTANCE,-1,-1;BOTTOM_NS_CODE \"BOTTOM_NS_CODE\" true true false 1 Text 0 0 ,First,#,,BOTTOM_NS_CODE,-1,-1;BOTTOM_EW_DISTANCE \"BOTTOM_EW_DISTANCE\" true true false 8 Double 0 0 ,First,#,,BOTTOM_EW_DISTANCE,-1,-1;BOTTOM_EW_CODE \"BOTTOM_EW_CODE\" true true false 1 Text 0 0 ,First,#,,BOTTOM_EW_CODE,-1,-1;BOTTOM_BLOCK_NAME \"BOTTOM_BLOCK_NAME\" true true false 255 Text 0 0 ,First,#,,BOTTOM_BLOCK_NAME,-1,-1;TOTAL_DEPTH_DATE \"TOTAL_DEPTH_DATE\" true true false 255 Text 0 0 ,First,#,,TOTAL_DEPTH_DATE,-1,-1;STATUS_DATE \"STATUS_DATE\" true true false 255 Text 0 0 ,First,#,,STATUS_DATE,-1,-1;TYPE_CODE \"TYPE_CODE\" true true false 1 Text 0 0 ,First,#,,TYPE_CODE,-1,-1;DISTRICT_CODE \"DISTRICT_CODE\" true true false 2 Text 0 0 ,First,#,,DISTRICT_CODE,-1,-1;STATUS_CODE \"STATUS_CODE\" true true false 3 Text 0 0 ,First,#,,STATUS_CODE,-1,-1;WATER_DEPTH \"WATER_DEPTH\" true true false 8 Double 0 0 ,First,#,,WATER_DEPTH,-1,-1;SURFACE_LONGITUDE \"SURFACE_LONGITUDE\" true true false 8 Double 0 0 ,First,#,,SURFACE_LONGITUDE,-1,-1;SURFACE_LATITUDE \"SURFACE_LATITUDE\" true true false 8 Double 0 0 ,First,#,,SURFACE_LATITUDE,-1,-1;BOTTOM_LONGITUDE \"BOTTOM_LONGITUDE\" true true false 8 Double 0 0 ,First,#,,BOTTOM_LONGITUDE,-1,-1;BOTTOM_LATITUDE \"BOTTOM_LATITUDE\" true true false 8 Double 0 0 ,First,#,,BOTTOM_LATITUDE,-1,-1;SURFACE_LEASE_NUMBER \"SURFACE_LEASE_NUMBER\" true true false 255 Text 0 0 ,First,#,,SURFACE_LEASE_NUMBER,-1,-1", "")
It's a direct export from the model built.
# Import arcpy module import arcpy # Set the workspace environment to local file geodatabase arcpy.env.workspace = r"C:\FoB Oil and Gas\GoM\WorkSpace.gdb" try: # Local variables: WELLS_1 = "C:\\FoB Oil and Gas\\GoM\\GOM_Spatial.mdb\\WELLS" tbl = "C:\\FoB Oil and Gas\\GoM\\3_Compare\\Compare.mdb\\WELLS" lyr = "WELLS_Layer" # Set the spatial reference spRef = r"Coordinate Systems\Geographic Coordinate Systems\North America\GCS_North_American_1927.prj" # Process: Make XY Event Layer arcpy.MakeXYEventLayer_management(tbl, "SURFACE_LONGITUDE", "SURFACE_LATITUDE", lyr, spRef, "") # Print the total rows print arcpy.GetCount_management(lyr) except: print arcpy.GetMessages()
# Import arcpy module import arcpy # Set the workspace environment to local file geodatabase arcpy.env.workspace = r"C:\FoB Oil and Gas\GoM\WorkSpace.gdb" try: # Local variables: tbl = "C:\\FoB Oil and Gas\\GoM\\3_Compare\\Compare.mdb\\WELLS" lyr = "WELLS_Layer" # Process: Make XY Event Layer arcpy.MakeXYEventLayer_management(tbl, "SURFACE_LONGITUDE", "SURFACE_LATITUDE", lyr, "", "") # Print the total rows print arcpy.GetCount_management(lyr) except: print arcpy.GetMessages()
#Import arcpy module import arcpy, os # Set the workspace environment to local file geodatabase arcpy.env.workspace = ws = r"C:\FoB Oil and Gas\GoM\WorkSpace.gdb" spa_ref = r'C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Geographic Coordinate Systems\North America\NAD 1927.prj' try: # Local variables: tbl = r"C:\FoB Oil and Gas\GoM\3_Compare\Compare.mdb\WELLS" lyr = "WELLS_Layer" # Process: Make XY Event Layer arcpy.MakeXYEventLayer_management(tbl, "SURFACE_LONGITUDE", "SURFACE_LATITUDE", lyr, spa_ref) # Print the total rows print arcpy.GetCount_management(lyr) arcpy.FeatureClassToFeatureClass_conversion(lyr, ws, 'WELLS_Points') print 'Created Feature Class' except: tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n\t" + \ str(sys.exc_type) + ": " + str(sys.exc_value) + "\n" msgs = "ARCPY ERRORS:\n" + arcpy.GetMessages(2) + "\n" arcpy.AddError(msgs) arcpy.AddError(pymsg) print msgs print pymsg arcpy.AddMessage(arcpy.GetMessages(1)) print arcpy.GetMessages(1)
sr = arcpy.SpatialReference(factoryCode)Where factoryCode is the WKID (well-known ID), that isn't so well known (just a small joke there, sorry). Maybe wrong, but this may set if correctly for you:sr = arcpy.SpatialReference(104145)
# Process: Make XY Event Layer, WKID 4267 is NAD 1927 in 10.1 arcpy.MakeXYEventLayer_management(tbl, "SURFACE_LONGITUDE", "SURFACE_LATITUDE", lyr, 4267)
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
