# Import Modules import arcpy, os # Set Variables mxdpath = r'FULL PATH TO MXD FILE' # string outputfolder = 'FULL PATH TO OUTPUT FOLDER' # string namefield = 'THE FIELD CONTAINING THE NAME OF THE RESULTING PDF FILE' # string queryfield = 'THE FIELD CONTAINING THE VALUE FOR THE DESIRED QUERY' # string layers = ['LIST','OF','LAYERS'] # list mxd = arcpy.mapping.MapDocument(mxdpath) # Start Loop through Data Driven Pages for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1) mxd.dataDrivenPages.currentPageID = pageNum # set the current page pageName = mxd.dataDrivenPages.pageRow.getValue(field) # get the pageName pageName += '.pdf' # add '.pdf' extension for file name pdf = os.path.join(outputfolder, pageName) # add pageName to output folder to get full output path # Start Loop through all layers of mxd file for lyr in arcpy.mapping.ListLayers(mxd) # for every layer in mxd's Layer List if lyr.name in layers: # if layer name in user input list above value = mxd.DataDrivenPages.pageRow.getValue(queryfield) # get value of query field if lyr.defintionQuery == True: # if a defintionQuery Exsts... query = lyr.defintionQuery + "AND QueryField = \'%s\'" % (value) # Add new to old else: query = "QueryField = \'$s\'" % (value) # else create a new query lyr.defintionQuery = query # set the layers defintionQuery else: print 'Next' # else print next, this isn't necassary, but its a good place holder arcpy.mapping.ExportToPDF(mxd, pdf) # export the current Page to pdf del mxd, lyr, pageName, pageNum, query, value
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
