Why do you use __file__ infilename = os.path.abspath(__file__) ?Why not filename = os.path.abspath(fc)I also assume that the filename variable needs to be properly quoted before being passed to CalculateFieldarcpy.CalculateField_management(fc, 'shpname', r'"%s"' % (filename), "PYTHON" )- that is, with double quotes (required by calculate field) surrounded by single quotes (needed to pass the double quotes as part of the string)
for fc in fcLst: filename = "'" + os.path.abspath(__file__) + "'" arcpy.AddField_management(fc, 'shpname','text') arcpy.CalculateField_management(fc, 'shpname',filename, "PYTHON" )
Hi David,Add single quotes to your 'filename' variable. Try the following:for fc in fcLst: filename = "'" + os.path.abspath(__file__) + "'" arcpy.AddField_management(fc, 'shpname','text') arcpy.CalculateField_management(fc, 'shpname',filename, "PYTHON" )
filename = "'" + arcpy.env.workspace + os.sep + fc + "'"
import arcpy from arcpy import env import os import time def main(): try: import arcpy, sys, traceback, os, glob, shutil arcpy.env.overwriteOutput = True log = r'Q:\1-EMPLOYEE INBOX\David\downloads\logSurveyData.txt' masterFolder = r"Q:\GIS\Field_Data\MT" outputFolder = r"C:\tmp\Shp_merged" dst = r'Q:\GIS\Field_Data\z_archive\PMM' #shutil.copytree(masterFolder, dst + time.strftime('%m_%d_%y')) #collect a list of subfolders in master folder arcpy.env.workspace = masterFolder arcpy.ListWorkspaces('','Folder') subfolderLst = arcpy.ListWorkspaces('','Folder') print subfolderLst for subfolder in subfolderLst: arcpy.env.workspace = subfolder fcLst = arcpy.ListFeatureClasses() for fc in fcLst: #file = fc in fcLst filename = "'" + arcpy.env.workspace + os.sep + fc + "'" print filename arcpy.AddField_management(fc, 'shpname','text') arcpy.CalculateField_management(fc, 'shpname', filename, "PYTHON" ) except: print arcpy.GetMessages() # Get the traceback object '"' + wildcard + '"' tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate information together concerning the error into a # message string pymsg = tbinfo + "\n" + str(sys.exc_type)+ ": " + str(sys.exc_value) # Return python error messages for use with a script tool arcpy.AddError(pymsg) # Print Python error messages for use in Python/PythonWin print pymsg if __name__ == '__main__': main()
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
