I want to merge random polygons placed on a graphics layer make a single polygon with only one boundary. Also how to unmerge them.
I think this function works for only intersected boundaries: i used the solution below, and it is working fine.
merge.addEventListener('click',function(){ var updatedGeometry=new Array(); graphicsLayer.graphics.map(function(gra){ updatedGeometry.push(new Polygon((gra.geometry))); }); var joinedPolygons = geometryEngine.union(updatedGeometry); graphicsLayer.removeAll(); joinedPolygons.rings.forEach(function(ring) { resultpolygon={type:"polygon",rings:[ring]}; var resultgraphic =new Graphic({ geometry: resultpolygon, symbol: resultsymbol }); graphicsLayer.add(resultgraphic); // console.log(ring); }); });
jQuery('#main').on('click','.merge_boundary',function(){ var updatedGeometry=new Array(); graphicsLayer.graphics.map(function(gra){ updatedGeometry.push(webMercatorUtils.webMercatorToGeographic(gra.geometry)); }); var joinedPolygons = geometryEngine.union(updatedGeometry);//it returned all polygons as it is, do not merge to make it one console.log(joinedPolygons.rings); addGraphics(joinedPolygons.rings); });
Correct. The Union works with the actual geometry not the layer.
hi robert,
long time to hear from your side... how are you, well thanks for the reply, i already get the union link, but couldn't find any example, if u have any link then pls send..
like i have found this
Merge Polygons in JavaScript API 4.14
Do, i need to to loop through all the polygons of a layer, to get its graphics geomtrry
Merge/Union: https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-geometryEngine.html#union
To un-merge you loop though the Polygons rings and copy those ring arrays to another Polygon class.
