If you are using IIS, you can let Active Directory do the authentication based on the windows credentials. ArcGIS Server can use AD for a user store and your services can be accessed based on the authentication/authorization from the store.
<script type="text/javascript"> dojo.require("dojo.parser"); dojo.require("esri.IdentityManager"); var cred = "esri_jsapi_id_manager_data"; var shortLivedTokenValidity=60; function init() { var idBase = new esri.IdentityManagerBase(); esri.config.defaults.io.proxyUrl = "proxy.ashx"; var serverInfo = { "server": "http://myserver:8399", "tokenServiceUrl": "http://myserver/arcgis/tokens", "currentVersion": 10.4 }; var def = idBase.generateToken(serverInfo, { "username": "rahul", "password": "rahul" }); def.addCallback(function (tokenInfo) { var idBase = new esri.IdentityManagerBase(); //Short lived token is valid for 60 mins by defult idBase.tokenValidity =shortLivedTokenValidity=60; var serverInfo = { "server": "http://myserver:8399", "tokenServiceUrl": "http://csslsystem-254:8399/arcgis/tokens", "currentVersion": 10.04 }; esri.id.registerServers([serverInfo]); //get token creation time in epoch var creationTime = (new Date).getTime(); //calculate the token expiration based on short lived token validity var expirationTime = creationTime + (shortLivedTokenValidity * 60000); //create array of secured services var securedServices = []; for (var services in this.configData.mapService) { securedServices.push(this.configData.mapService[services]); } var idString = dojo.toJson({ "serverInfos": [serverInfo], "credentials": [{ "userId": rahul, "server": "http://myserver:8399", "token": tokenInfo.token, "expires": expirationTime, "ssl": false, "creationTime": creationTime, "resources": securedServices }] }); // store it client side if (_supports_local_storage()) { // use local storage window.localStorage.setItem(this._jsAPIIDManagerData, idString); } else { // use a cookie dojo.cookie(this._jsAPIIDManagerData, idString, { expires: 1 }); } this._loadCredentials(); }); } function _supports_local_storage() { try { return "localStorage" in window && window["localStorage"] !== null; } catch (e) { return false; } } function _loadCredentials() { var idJson, idObject; if (this._supports_local_storage()) { // read from local storage idJson = window.localStorage.getItem(this._jsAPIIDManagerData); } else { // read from a cookie idJson = dojo.cookie(this._jsAPIIDManagerData); } if (idJson && idJson != "null" && idJson.length > 4) { idObject = dojo.fromJson(idJson); esri.id.initialize(idObject); } } dojo.addOnLoad(init); </script>
var getToken = function(onComplete){ dojo.xhrGet({ url: this.basePath + "code/getFwpTokenNew.jsp?ref=" + document.location.protocol + "%2F%2F" + document.location.hostname, handleAs: "text", load: function(data){ var jsonData = dojo.fromJson(data); onComplete(jsonData.token); }, error: function(error){ console.debug(error); } }); };
<%@page session="false"%> <%@page import="java.net.*,java.io.*" %> <% response.setHeader("Cache-Control","no-cache"); //HTTP 1.1 response.setHeader("Pragma","no-cache"); //HTTP 1.0 response.setDateHeader ("Expires", 0); //prevents caching at the proxy server String onErrorText = ""; try { String reqUrl = request.getQueryString(); String onProd = request.getParameter("prodServer"); String refUrl = request.getParameter("ref"); String agsServerUserName = "username"; String agsServerPswd = "password"; String agsServerPath = "http://yourserverpath"; out.clear(); String getTokenUrl = agsServerPath +"/arcgis/tokens/gettoken?request=getToken&username="+agsServerUserName+"&password="+agsServerPswd+"&clientid=ref."+refUrl+"&expiration=1440"; URL tokenRequest = new URL(getTokenUrl); BufferedReader in1 = new BufferedReader(new InputStreamReader(tokenRequest.openStream())); String token = in1.readLine(); in1.close(); out.println("{'token':'"+token+"'}"); return; } catch(Exception e) { out.println("{'error':'There was retrieving the token for the map server.'}"); } %>
