sylvain.kerdreux.does the generated mxd file contain invalid layers or are there no layers in it.If there are no layers in it, that means that either the server couldn't access the lyr-files or the layer was invalid.Could you post the server.log from ArcGIS Server in verbose log?. The reason should be written in it.If ther are layers in it but they aren't displayed, please add the manually and check the difference between them in the properties.Tom
ERROR unable to add mapservice layers for :http://vm-geotest/arcgis/rest/services/Fond_de_plan/MapServer 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST INFO3 addAGSMapServiceByLayerFile.agsMapServiceLayerUrl = http://vm-geotest/arcgis/rest/services/Fond_de_plan/MapServer?f=lyr&v=9.3 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST ERROR AutomationException: One or more arguments are invalid 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST INFO3 mapService: http://vm-geotest/arcgis/rest/services/Fond_de_plan/MapServer 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST
UnkleJ,you have to configure the virtual output directory on your "Printing" mapservice.If you have configured it, could you please post the ArcGIS server log in verbose mode.Tom
I'm having an issue where the red print extent box remains on the display after the widget is closed. Is there a fix for this with the compiled version? See the attached image.
conner_justin,I hope to get some time this week to fix this bug and to make it fully 2.4 compatible.Tom
cvance15,please checkout the latest commits at:http://bitbucket.schuller.luImage size is now respecting the height and width properties.Tom
Hy Eric,I just downloaded the latest sources of the bitbucket page:http://bitbucket.schuller.lu/pchprintwidget/get/f79824d69e04.zipI also downloaded the FlexViewer 2.5:https://github.com/ArcGIS/ArcGISViewerForFlex/zipball/flexviewer-2.5-srcI copied from the pchprintwidget the complete "src" directory to the flexviewer src directory (asked to override the config.xml)I added the "src\lu\etat\pch\gis\widgets\pchPrintWidget\PchPrintWidget.mxml" as module in the FlashBuilder project.It compiled successfully and worked out-of-the box.How did you downloaded the latest source?Which small tweaks did you added to your version? May be I could integrate them directly in the codebase?Tom
Eric,could you mail me your project?tom@schuller.luI will check it. Seems to be something wrong.I'm currently on Flex SDK 4.5.1Tom
Eric,your project seems to miss some needed files.You can get the complete sources under:http://bitbucket.schuller.lu/pchprintwidget/src upper right corner "get source" -> zip fileTom
Eric,when clicking on the "get source" button,you should get this link:http://bitbucket.schuller.lu/pchprintwidget/get/f79824d69e04.zipThis download should contain the binaries and the source files.I also attached it to this post, so you can check if it solves your problem.Tom
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
