ericv,the jar file seems to contain the source files (xyz.java).It should contain the compiled files (xyz.class).You could open the jar with a simple zip-client to see the content.Tom
{ "href": "http://gisdev.hallsberg.se:8399/arcgis/server/arcgisoutput/_ags_map392d5114a7cd11e08538080027ac2eb4.png", "width": 400, "height": 400, "extent": { "xmin": 1459300, "ymin": 6549050.000000001, "xmax": 1460400, "ymax": 6550150.000000001, "spatialReference": {"wkid": 3021} }, "scale": 10393.679999999998 }
http://10.202.101.108:8399/arcgis/rest/services/layout/MapServer/exts/PCHPrintSOE/printMap?mapExtent={"xmin":1459087.998475997,"ymin":6549246.780543561,"xmax":1460612.001524003,"ymax":6549953.219456439,"spatialReference":{"wkid":3021}}&printOutput={"mapRotation":0,"pageUnits":1,"format":"pdf","exportSettings":null,"height":9.673913043478262,"width":20.869565217391305,"toRemoveLayoutElements":[],"resolution":92,"borderWidth":[0.5,0.5,0.5,0.5]}&mapElements=[]&layoutElements=[]&mapServices=[{"alpha":1,"visibleIds":"0,1,2,5,6,7","type":"AGS","url":"http://10.202.101.108:8399/arcgis/rest/services/BGK/BGKtest/MapServer","name":"testMap"}] or if in the other state of the widget something longer like: http://10.202.101.108:8399/arcgis/rest/services/layout/MapServer/exts/PCHPrintSOE/printLayout?mapExtent={"xmin":1459785.9770552877,"ymin":6549455.489437812,"xmax":1459885.9770552877,"ymax":6549598.989437812,"spatialReference":{"wkid":3021}}&printOutput={"resolution":100,"format":"pdf","exportSettings":null,"width":21,"height":29.7,"borderWidth":[0.5,0.5,0.5,0.5],"toRemoveLayoutElements":["*"],"mapRotation":0,"pageUnits":8}&mapElements=[]&layoutElements=[{"xOffset":0,"yOffset":0,"anchor":"bottomleft","symbol":{"size":48,"type":"pchNorthArrow"},"geometry":{"x":0.5,"y":0.5},"visible":true,"name":null},{"xOffset":0,"yOffset":0,"anchor":"topmid","symbol":{"text":"Title","textSymbol":{"angle":0,"color":{"green":0,"alpha":255,"blue":0,"red":0},"text":null,"font":null,"xoffset":0,"yoffset":0,"borderLineColor":null,"type":"agsJsonSymbol"},"type":"pchTextElement"},"geometry":{"x":10.5,"y":29.2},"visible":true,"name":"myTitle"},{"xOffset":0,"yOffset":0,"anchor":"bottomleft","symbol":{"barHeight":5,"type":"pchScaleBar"},"geometry":{"x":0.5,"y":0.5},"visible":true,"name":"myScaleBar"},{"xOffset":0,"yOffset":0,"anchor":"bottommid","symbol":{"text":"© copyright pch","textSymbol":{"angle":0,"color":{"green":255,"alpha":255,"blue":255,"red":255},"text":null,"font":null,"xoffset":0,"yoffset":0,"borderLineColor":null,"type":"agsJsonSymbol"},"type":"pchTextElement"},"geometry":{"x":10.5,"y":0.5},"visible":true,"name":"myCopyRight"},{"xOffset":0,"yOffset":0,"anchor":"topleft","symbol":{"mapUnits":8,"separator":":","pageUnits":9,"backgroundColor":{"green":255,"alpha":255,"blue":255,"red":255},"style":0,"numberFormat":{"roundingOption":0,"roundingValue":3},"pageUnitLabel":"","mapUnitLabel":"","type":"pchScaleText"},"geometry":{"x":0.5,"y":29.2},"visible":true,"name":null}]&mapServices=[{"alpha":1,"type":"AGS","url":"http://10.202.101.108:8399/arcgis/rest/services/BGK/BGKtest/MapServer","name":"testMap","visibleIds":"0,1,2,5,6,7"}]
1084: function 'getClass' will be scoped to the default namespace: BaseWidget: internal. It will not be visible outside of this package. PchPrintWidget.mxml /Hallsbergskartan_231_test/src/lu/etat/pch/gis/widgets/pchPrintWidget line 488 Flex Problem 3596: Duplicate variable definition. PchPrintWidget.mxml /Hallsbergskartan_231_test/src/lu/etat/pch/gis/widgets/pchPrintWidget line 469 Flex Problem
warning: unable to bind to property 'selected' on class 'Object' (class is not an IEventDispatcher) warning: unable to bind to property 'popupClass' on class 'Object' (class is not an IEventDispatcher) warning: unable to bind to property 'visible' on class 'Object' (class is not an IEventDispatcher) warning: unable to bind to property 'label' on class 'Object' (class is not an IEventDispatcher) warning: unable to bind to property 'editable' on class 'Object' (class is not an IEventDispatcher)
&mapServices= [{"alpha":1,"type":"AGS","url":"http://10.202.101.108:8399/arcgis/rest/services/BGK/BGKtest/MapServer","name":"testMap","visibleIds":"0,1,2,5,6,7"}]
sylvain.kerdreux,could you try this url on your server:http://vm-geotest/ArcGIS/rest/services/CarteGenerale/MapServer?f=lyr&v=9.3This should give you a "lyr" file containing the mapservice.Could you try to add it to ArcMAP?`Are all layers visible?If you have ArcMAP on your server "VM-GEOTEST", try it directly on the server.Tom
mapExtent {"xmin":1459779.8223054777,"ymin":6549481.999576666,"xmax":1459879.8223054777,"ymax":6549625.499576666,"spatialReference":{"wkid":3021}} layoutElements [{"symbol":{"type":"pchNorthArrow","size":48},"visible":true,"name":null,"geometry":{"x":0.5,"y":0.5},"yOffset":0,"xOffset":0,"anchor":"bottomleft"},{"symbol":{"textSymbol":{"borderLineColor":null,"xoffset":0,"type":"agsJsonSymbol","angle":0,"yoffset":0,"text":null,"font":null,"color":{"green":0,"alpha":255,"blue":0,"red":0}},"type":"pchTextElement","text":"Title"},"visible":true,"name":"myTitle","geometry":{"x":10.5,"y":29.2},"yOffset":0,"xOffset":0,"anchor":"topmid"},{"symbol":{"barHeight":5,"type":"pchScaleBar"},"visible":true,"name":"myScaleBar","geometry":{"x":0.5,"y":0.5},"yOffset":0,"xOffset":0,"anchor":"bottomleft"},{"symbol":{"textSymbol":{"borderLineColor":null,"xoffset":0,"type":"agsJsonSymbol","angle":0,"yoffset":0,"text":null,"font":null,"color":{"green":255,"alpha":255,"blue":255,"red":255}},"type":"pchTextElement","text":"�?© copyright pch"},"visible":true,"name":"myCopyRight","geometry":{"x":10.5,"y":0.5},"yOffset":0,"xOffset":0,"anchor":"bottommid"},{"symbol":{"numberFormat":{"roundingOption":0,"roundingValue":3},"pageUnitLabel":"","mapUnitLabel":"","mapUnits":8,"type":"pchScaleText","backgroundColor":{"green":255,"alpha":255,"blue":255,"red":255},"pageUnits":9,"separator":":","style":0},"visible":true,"name":null,"geometry":{"x":0.5,"y":29.2},"yOffset":0,"xOffset":0,"anchor":"topleft"}] mapElements [] f json printOutput {"mapRotation":0,"width":21,"height":29.7,"resolution":100,"pageUnits":8,"toRemoveLayoutElements":["*"],"format":"pdf","exportSettings":null,"borderWidth":[0.5,0.5,0.5,0.5]} mapServices [{"name":"BGKtest_mxd","alpha":1,"visibleIds":"0,1,2,5,6,7","type":"AGS","url":"http://10.202.101.108:8399/arcgis/rest/services/BGK/BGKtest_mxd/MapServer"}]
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
