Is anyone else able to reproduce this error?
Dan
Dan,
Yes, I have been able to reproduce this.
Labeling enabled with the mapviewer is currenlty not supported in Dashboard.
Mark
An update
The September update to ArcGIS online should enable label support for Operations Views opened in the web browser.
At the time of this writing there is no definitive timeline for when map viewer map labeling will be supported in the Windows Dashboard Application.
Thanks Mark. That is good to know.
Hi Mark,
could you provide an update when labeling would be supported in the Windows Dashboard Application? We are 5 months later now, any news?
thx,
Dries
Still seems to not be working? I know labels are not supported in collector but from this post I am confused if I should see them in dashboard? I have a feature service setup in arcmap to display labels and published. I then enabled them in AGOL and they show fine on my webmap but using that webmap does not show the labels in dashboard.
Is there a timeline yet for feature service label support is the desktop version of the operations dashboard?
as we are at March 2016. is label support in the desktop version of the operations dashboard yet ?
but as workaround
if you could enable <label features> from ArcMap before Publishing service, you'll get this view at Ops Dashboard Desktop edition
Labeling is not possible due to limitations in the WPF architecture. We are working on a new version of Operations Dashboard that is based on JavaScript and will support labels (and many other things not previously supported).
Any timeframe?
Will this include labeling support for Operations Dashboard via Portal?
Adam Repsher- Public beta will be out shortly after UC and full release hopefully later this year.
Tiffany Selvidge- Yes, the portal release for the new dashboard will have the same functionality as the AGOL one.
This error persists with the latest version dashboard (10.3.4.1523), windows 10
The labels will not work in the desktop version because of the known limitation of it's framework. We encourage users who want to show labels to build their dashboards with the browser version in mind, or to switch to using our new Operations Dashboard, in which you can author in the browser. More details about that here and here.
Thanks!Chris
Thanks Chris,
and another question
Thank you for the video, that certainly helps with troubleshooting the issue! What you are seeing here, again, it's a limitation of the WPF platform. It has no understanding of the javascript symbols or expression, so it uses default symbology on the map. Also, the legend works, only because it's fetching the image from your webmap. As you also saw, there was no problem in the browser version, because it's using the same javascript library as the webmap.
All of these 'platform' limitations have been addressed in our new beta app. If you haven't already, I would encourage you to join the beta and start building your own dashboards in the browser. We have seen tremendous feedback on it and look forward to the future of the product. Thanks!
Thanks Crhis, I understand perfect, but in collector the same thing happens?
Https://www.screencast.com/t/6wjfeyA1B6
Hi Francesca,
My name is Kevin and I work on the Collector team. With regards to your last post, I was able to view your video.
The reason why your labels and symbology aren't displaying when the map is opened in Collector is because the current version of Collector doesn't support labels and also doesn't support Arcade Expressions, which your symbology is based off of.
We're currently working on the next generation version of Collector that we should be releasing for beta in the upcoming months. I am not sure that labels or support for Arcade expressions will make it into the first beta, but we plan on releasing a series of beta versions throughout the next several months that should address those as well as many other current limitations. Please keep an eye out for any upcoming blog posts regarding this new version of Collector and for more information about it.
Thank you.
-Kevin
Labels in Dashboard. My workaround in the new online Dashboard was to add my map with labels as Embedded Content URL instead of adding as a Map. I don't know if Embedded Content has always been in the dropdown with graph, pie chart, map, serial chart, indicator, but it works. I can't tell the difference between adding as a Map vs adding as Embedded Content. I can also use the Batch Editing widget in the map within Dashboard.
