I'm a real newbie and have a web app that embeds an ArcGIS map using the JavaScript API. I used the sample code from the following and have my app working:http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples/map_explicitlayerlist.htmlIf you visit the URL above, you'll see it uses layer ids for the default layers to be displayed (i.e., "imageParameters.layerIds = [2];" and "visible = [2];"). I currently have mine set to use layer ids, but I needed more than 1 layer displayed by default, so I currently have: "imageParameters.layerIds = [0,1,20,21,22];" and "visible = [0,1,20,21,22];".However, over time, the layer order will change because I'll be adding new layers. Therefore, I want to refer to the layers by name, instead of id.How do I modify the code at the sample URL above to set the default layers to display using layer names, instead of layer ids?Thanks,Steve
For both ArcGISDynamicMapServiceLayer and ArcGISTiledMapServiceLayer, there is a property call layerInfos which is LayerInfo[]. Each element of the array is a object of LayerInfo which has id, name etc properties. You can use it for your purpose. See Javascript API Reference for more detail.
Do you have an updated version of this code?
I want the updated version of this code !! Anyone help kindly
