I have published a Feature Service on our ArcGIS Server 10.4.1 and in support section of the Feature Service URL I am seeing that the
ApplyEdits With Global Ids: false
can you please let me know why this is false? and how can I update it to True?
Hi Bengi,
From the help:
ArcGIS REST API
hello @José_LuisCc ,
i have the same problem in arcgis enterprise 10.9.1your solution was to enable synchronization and replication in feature service?
@elpinguinoDid your approach work? recreating the attachment tables? or recreating indexes?
thanks!
@elpinguino- finally got access to my account again...sorry for the delay - but for you and for anyone else who has this issue - what I mean is this:
Remove index:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/remove-attribute-index.htm
Add index:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/add-attribute-index.htm
you can also go into the layer properties -in pro or arc catalog and go to Indexes. From there - delete the existing index on the GUID field and re add it but be sure to check the "UNIQUE" checkbox.
The rules to ensuring that the applyEditsWithGlobalIDs is true are as follows:
1. Check that all layers and tables have a global ID and unique constraint index on them
2. Check that all attachment tables related to each layer and table has global ids
3. Ensure the attachment table relationship USES the global id field/guid in the relationship - so check the Attachments_REL relationship class and make sure that it uses the Global ID field.
4. Ensure each attachment table has the global id unique index constraint
5. Ensure all relationships for layers in the service use global ids to participate in the relationship (including attachment relationships).
You can usually browse the /arcgis/rest/services/ServiceName/MapServer/<LAYERID> endpoint of the service for each layer to see which one is the culprit .
I had to do this as well. My issue was I was importing a feature class with attachments and GlobalIDs already in place. I had to build a brand new feature class replicating the existing one. Then I needed to give it GlobalIDs, enable attachments and also enable archiving for the value to change to 'ApplyEdits with GlobalIDS : true'. After that was successful I appended my old data that I downloaded from AGOL into this new feature class.
Activate synchronization (update disconnected with synchronization).
All right !
Hi Gregg,
Not sure if you'll see this post, but hoping someone in the thread will. I'm having this issue. If I go in to each feature layer in the feature service and turn off Enable attachments and then turn it back on, ApplyEditsWithGlobalIDs becomes true. It's fine to do this now because I'm still in the development stage, but once this goes live, that's going to be a problem if I have to keep doing this because then we'll lose any forms or images the field workers have attached. What do you mean in your post above about re-add it with the Unique constraint? What is the unique constraint? Did you do this in Arcpro or AGOL? Are you saying I shouldn't apply GlobalIDs except for the one main feature layer that everything relates back to, and for the rest only have GUIDs?
Thanks for sharing this "hack", Brian. I imagine that as Gregg points out below, this re-indexes the Global ID field for the layer with attachments enabled. But unlike Gregg, we don't have access to the RDBMS behind the scenes in an ArcGIS Online hosted feature service.
FYI: Your method worked for me only after I disabled/enabled attachments for every layer in the feature service.
I also attempted to update the service definition by editing the JSON at the rest/admin/service endpoint (accessed by inserting "/admin" between "/rest" and "/service" in the service URL). Just changing "supportsApplyEditsWithGlobalIds" : to "true" did not stick. Re-indexing the Global ID fields seems to be required.
I'm not sure if there is method to do this using the API other than the disable/enable workflow you found. Maybe someone else with more developer skills can enlighten us. This would be the preferable method so that we don't lose any current attachments in the re-indexing process.
This worked for me too!!!
It seems to me a little counter intuitive to have to redefine indexes created autommatically by ArcGIS tools, but it worked...
P.S.: I recreated the indexes directly in the database server, through SQL statements (Oracle DBMS)
My solution to this was to go into the catalog view of the database, go to the table properties and Indexes, remove the GlobalID index, and re-add it with the Unique constraint. Do this on all layers in the feature services and supports ApplyEdits with GlobalIDS becomes true.
I also keep having this problem and found a way to fix it. I also started with a point feature class, a related table to the point feature class, and an attachment table related to the first table. I used an Esri Guid field with the same name in all the tables for the relationships. The service published fine from ArcMap, but when I went to ArcGIS Online and looked at the JSON for each (point, table, attachment table), the point and first table (which had attachments disabled) both showed the supportsApplyEditsWithGlobalIds as true but the attachment table (attachments enabled) showed supportsApplyEditsWithGlobalIds as false. What I did was to disable the attachments from the attachment table and then re-enabled it. When I checked the JSON again it showed supportsApplyEditsWithGlobalIds as true. I was then able to create a survey with Survey123 Connect for ArcGIS using the published Feature Service in ArcGIS Online. I have no clue why this worked, but it did.
I'm also running into this in 10.7 on a postgres geodatabase. I've already verified that every table has archiving enabled, has globalids and the attachments use global ids.
What else is there to check?
Hi Jake
How do we update so that apply edits on globalids is supported?
I'm in a similat boat to Jordan and seem to be going around in circles with what is supported in Pro, online and Survey123.
I'm having issues with this setting as well.
I've launched a feature service with a point layer and two related tables from a file geodatabase in ArcMap via ArcGIS Online
The relationships are based on the globalid and the origin is set to the parent (point) layer
I allowed all operations in the feature access tab
After the service is launched when I look at the JSON from the feature service it shows that the apply global edits is set to false:
"supportsApplyEditsWithGlobalIds" : false, "editorTrackingInfo" : { "enableEditorTracking" : false, "enableOwnershipAccessControl" : false, "allowOthersToQuery" : true, "allowOthersToUpdate" : true, "allowOthersToDelete" : false, "allowAnonymousToUpdate" : true, "allowAnonymousToDelete" : true },
What else am I missing here?
I've read through this: Use Survey123 with existing feature services—Survey123 for ArcGIS | ArcGIS
I'm trying to set up a survey that has multiple related tables.
