I'm trying to implement a Water Utility Network and am having trouble with my taps or junctions. We have serveral mains that have taps connected at vertex's in the span at the main. Then a service line is connected to that tap. If this tap is connected in the span of the main instead of the end the Is Connected tool and Update Subnetwork does not assign the service line or the tap to the system.
I was looking at the Naperville data and it shows whole mains without the mains split at the taps for the service lines. I'm also tried splitting a line or making a line off a controllable value and it still doesn't work correctly.
I disable and re-enabled network topology hoping this would help. I also verified under the Water Line that the Network Edge Connection Policy is set to Any Vertex on Water Mains and Service Lines
