On hindsight this thread should probably be in import/export...anyway any news on those files that are causing my CE to close? It seems I can't import any kmz file, every one I've tried instantly shuts down CE, so as a result it gets very frustrating!
New query as well (sorry about all the questions!) So When I import as collada dae from sketchup why are not all my textures included? Check out the image attached. Basically this building should have all the roof the same texture (this is what it is in sketchup) but as you can see when it's imported some of the roof's turn up blank! how can I fix this?thanks!!!
If CE does not find the texture, either the texture is actually missing or the file path to it is wrong.Use the standard file navigation conventions :Examples:images/myTexture.jpg --> CE will search the image in the images folder.images/myFolder/myTexture.jpg --> CE will search the image in images/myFolder.I assume this is the issue, so please double check both the paths and if the textures really are there. CE does not search further than that given path. Subfolders are NOT checked.If you open a COLLADA file in a text editor and search for the file paths, you can also see this:../myFolder/myTexture.jpg'..' means go up one directory, then go to the folder called 'myFolder' to find the file. That structure would be used if the collada file is in 1 folder and it's textures in an other. Adapt all those paths according to your file structure if CE does not find them.TIP :'Search and Replace' works also over multiple files with some text editors. E.g. with the free tool called 'NotePad++' ( http://notepad-plus-plus.org/ ) , you can search and replace texts in folders and subfolders, editing 100s of files if needed !
