#import arcpy and arcgisscriptingimport arcgisscriptinggp = arcgisscripting.create(9.3)gp.overwriteOutput = 1import arcpy# Set the current workspacegp.env.workspace = r"X:\mohammadi\finalmunichGIS\clip0ffishnet9000\clip"# Get and print a list of GRIDs from the workspacerasters = arcpy.ListRasters("*", "TIF")for raster in rasters: print(raster)# input hard-coded but you can make it a script tool parameter to make it an interactive input.#in_fc = r"X:\mohammadi\finalmunichGIS\clip0ffishnet9000\clip" # this polygon feature class has several polygons.rows = gp.SearchCursor(rasters)row = rows.Next()while row: feat = row.raster ext = feat.extent orig = str(ext.xmin) + " " + str(ext.ymin) yaxis = str(ext.xmin) + " " + str(ext.ymin + 100.00) opp_corner = str(ext.xmax) + " " + str(ext.ymax) print orig, yaxis, opp_corneroutPath = r"X:\mohammadi\finalmunichGIS\fishnet4500\4500.shp"+ str(row.OBJECTID)result = gp.CreateFishnet_management(outPath, orig, yaxis, "0", "0", "2", "2", opp_corner,"NO_LABELS","#","POLYGON") print(gp.GetMessages()) row = rows.Next()del row, rows
import arcpy from arcpy import env env.workspace = r"X:\mohammadi\finalmunichGIS\clip0ffishnet9000\clip" lstRasters = arcpy.ListRasters("*", "TIF") for raster in lstRasters: xmin = arcpy.Describe(raster).extent.XMin ymin = arcpy.Describe(raster).extent.YMin xmax = arcpy.Describe(raster).extent.XMax ymax = arcpy.Describe(raster).extent.YMax ymin2 = arcpy.Describe(raster).extent.YMin + 10 arcpy.CreateFishnet_management("fishnet_" + raster[:-4] + ".shp", str(xmin) + " " + str(ymin), str(xmin) + " " + str(ymin2), "0","0","2","2", str(xmax) + " " + str(ymax), "NO_LABELS", "#","POLYGON") print "Finished"
# only import arcpy - don't use arcgisscripting/gp at 10.ximport arcpyfrom arcpy import envarcpy.env.overwriteOutput = True ## 1env.workspace = r"X:\mohammadi\finalmunichGIS\munich.gdb"# in_fc is your polygon feature classin_fc = r"X:\mohammadi\finalmunichGIS\fishnet4500" fcList = arcpy.ListFeatureClasses("","Polygon","")for fc in fcList: lyrFC = "lyrFC" # in_fc is your polygon feature class in_fc = fc # in_tif is your input in_raster = r"X:\mohammadi\finalmunichGIS\Testdatenoriginaldata\munich_subset.tif" # output location outPath = r"X:\mohammadi\finalmunichGIS\lastclip" arcpy.MakeFeatureLayer_management(in_fc,lyrFC) # get list of object ids objIDs = [] objIDField = arcpy.Describe(lyrFC).OIDFieldName rows = arcpy.SearchCursor(lyrFC) row = rows.next() while row: objIDs.append(row.getValue(objIDField)) row = rows.next() del row, rows # temp polygons copyFC = r"X:\mohammadi\finalmunichGIS\test.gdb\fc_parent1_1c" # one by one clip raster to polygons arcpy.env.workspace= outPath for objID in objIDs: where = "{0} = {1}".format(objIDField,objID) arcpy.SelectLayerByAttribute_management(lyrFC,"NEW_SELECTION",where) arcpy.CopyFeatures_management(lyrFC,copyFC) ext = arcpy.Describe(copyFC).Extent extString = "{0} {1} {2} {3}".format(ext.xmin, ext.ymin, ext.xmax, ext.ymax) out_raster = "{0}_clip{1}.tif".format(in_fc, objID) arcpy.Clip_management(in_raster, extString, out_raster, copyFC) print arcpy.GetMessages(0) arcpy.Delete_management(copyFC)
# only import arcpy - don't use arcgisscripting/gp at 10.ximport arcpyfrom arcpy import envarcpy.env.overwriteOutput = True ## 1env.workspace = r"X:\mohammadi\finalmunichGIS\fishnet4500\fishnet4500.gdb"# in_fc is your polygon feature class#in_fc = r"X:\mohammadi\finalmunichGIS\fishnet4500" fcList = arcpy.ListFeatureClasses("","Polygon","")for fc in fcList: lyrFC = "lyrFC" # in_fc is your polygon feature class in_fc = fc # in_tif is your input in_raster = r"X:\mohammadi\finalmunichGIS\Testdatenoriginaldata\munich_subset.tif" # output location outPath = r"X:\mohammadi\finalmunichGIS\lastclip" arcpy.MakeFeatureLayer_management(in_fc,lyrFC) # get list of object ids objIDs = [] objIDField = arcpy.Describe(lyrFC).OIDFieldName rows = arcpy.SearchCursor(lyrFC) row = rows.next() while row: objIDs.append(row.getValue(objIDField)) row = rows.next() del row, rows # temp polygons copyFC = r"X:\mohammadi\finalmunichGIS\test.gdb\test" # one by one clip raster to polygons arcpy.env.workspace= outPath for objID in objIDs: where = "{1} = {0}".format(objIDField,objID) arcpy.SelectLayerByAttribute_management(lyrFC,"NEW_SELECTION",where) arcpy.CopyFeatures_management(lyrFC,copyFC) ext = arcpy.Describe(copyFC).Extent extString = "{0} {1} {2} {3}".format(ext.xmin, ext.ymin, ext.xmax, ext.ymax) out_raster = "{0}_clip{1}.tif".format(in_fc, objID) arcpy.Clip_management(in_raster, extString, out_raster, copyFC) print arcpy.GetMessages(0) arcpy.Delete_management(copyFC)
# only import arcpy - don't use arcgisscripting/gp at 10.ximport arcpyfrom arcpy import envarcpy.env.overwriteOutput = True ## 1env.workspace = r"X:\mohammadi\finalmunichGIS\fishnet4500\fishnet4500plus.gdb"def sendmsg (msg): print msg arcpy.AddMessage(msg)fcList = arcpy.ListFeatureClasses("","Polygon","")for fc in fcList: env.workspace = r"X:\mohammadi\finalmunichGIS\fishnet4500\fishnet4500plus.gdb" lyrFC = "lyrFC" sendmsg (fc) # in_fc is your polygon feature class in_fc = fc arcpy.MakeFeatureLayer_management(in_fc,lyrFC) # in_tif is your input in_raster = r"X:\mohammadi\finalmunichGIS\Testdatenoriginaldata\munich_subset.tif" # output location outPath = r"X:\mohammadi\finalmunichGIS\clip0ffishnet9000\lastclip" # get list of object ids objIDs = [] objIDField = arcpy.Describe(lyrFC).OIDFieldName rows = arcpy.SearchCursor(lyrFC) row = rows.next() while row: objIDs.append(row.getValue(objIDField)) row = rows.next() del row, rows # temp polygons copyFC = r"X:\mohammadi\finalmunichGIS\test.gdb\fc_parent1_1c" # one by one clip raster to polygons arcpy.env.workspace = outPath for objID in objIDs: where = "{0} = {1}".format(objIDField,objID) arcpy.SelectLayerByAttribute_management(lyrFC,"NEW_SELECTION",where) arcpy.CopyFeatures_management(lyrFC,copyFC) ext = arcpy.Describe(copyFC).Extent extString = "{0} {1} {2} {3}".format(ext.xmin, ext.ymin, ext.xmax, ext.ymax) out_raster = "{0}_clip{1}.tif".format(in_fc, objID) arcpy.Clip_management(in_raster, extString, out_raster, copyFC) print arcpy.GetMessages(0) arcpy.Delete_management(copyFC) arcpy.Delete_management(lyrFC)
import arcpy from arcpy import env env.workspace = r"C:\TIFFs" env.overwriteOutput = 1 list = [] #append each raster to a list lstFCs = arcpy.ListFeatureClasses("*") for fc in lstFCs: list.append(fc) #iterate through each raster lstRasters = arcpy.ListRasters("*") for raster in lstRasters: for n in list: #find the fishnet shapefile by checking if the raster name is in the shapefile name if raster.split(".")[0] in n: rows = arcpy.SearchCursor(n) for row in rows: FID = row.FID #create a feature layer for each polygon in the fishnet shapefile arcpy.MakeFeatureLayer_management(n, "FC_lyr", "FID = " + str(FID)) #clip the raster by each polygon, and output a new TIFF to another directory arcpy.Clip_management(raster, "#", r"C:\TIFFs\Clip" + "\\" + raster + "_clip_" + str(FID) + ".tif", "FC_lyr", "256", "ClippingGeometry") print "Finished"
