When I open a new or existing project the moment I click the Analysis Tab(only) ArcGIS Crashes and the submit crash report opens. Same behavior if I try to open or run a geoprocessing tool from ArcCatalog pane or window. The last thing that I installed was the Data Interoperability Extension(DIE). Remove the DIE and re-installed ArcGIS Pro but still the same issue.
Have you tried running a repair on Pro? If not, can you give that a try?
Yes I did but it did not work.
I noticed that the crash happens after ArcGIS 2.4.3 tries to create the Geoprocessing Cache.
I found a "solution" here: https://community.esri.com/message/879103-re-arcgis-pro-crashes-when-it-tries-to-create-a-geoprocessing-cache?commentID=… with similar issue. The solution suggested to remove the PYTHOPATH variable. However, I do not have the PYTHONPATH variable. Any Feedback?
