Dear Experts , this is possible to use 2 Api in one Application,???
Example my Application Developed in 2.4 SL api and i want add some Tools from 3.2 SL Api ...
Possible Or Not???????
No, you can't mix 2 versions of a Library in one application.
Why not just migrate to 3.2 SL API?
Actually before my manager chose a template which is desighn in 2.4 api. We also modified some libraires for performence, now every thing is ok, but problem is that there are no server printing and no shape file upload tasks. Only i want this 2 functions... my silverlight is 5 but api is 2.4.
If there easy way for migrating then i will try but i cant update my codes for 3.2
Are u have idea how migrate easily
What do you mean? Did you run into issues when you compile after changing the ArcGIS SL version referenced?
Note that, for testing, you can install side by side multiple ArcGIS API for Silverlight versions. Make sure your project references the version you want to test.
Its not work with 3.2 but i will try on 3.0...
May be problem fixed..
We add some extra codes to dll
I think this is the problem
