We have several unit polygons that we are trying to merge as larger "collective" units and wonder if there is a way to merge them...? Thanks so much!
K. Lynn Martin
You can use the Dissolve tool if there is a common attribute, such as a name or id number, between the polygons.
Thank you for your reply, Lance! I looked at the link you sent and all the polygons in the example seem to be spatially adjacent to one another. Our polygons are scattered about spatially, but they do share a common name for the areas they "cover."
The tool will still work for non-adjacent features just make sure you select the "Create multipart features" check box. You would set "cover", or whatever the name of the common attribute, as your Dissolve Field.
We'll give it a whirl, Lance, thank you so much!
