Is it possible to remove the Widget header controls for some widgets or the map?
Specifically, I would like to remove the div which includes the widget title, maximise & close buttons. This is for WAB 2.7.
Thanks!
Baker,
You can use a CSS rule to hide those.
Here is a sample rule for hiding the title, close, minimize, etc on widget _5.
<SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.title-label</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.close-btn</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.max-btn</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#_5_panel.jimu-panel>.jimu-panel-title>.foldable-btn</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
