hellothank you for the insightI have noticed a bug in the API with the JMap toScreenPoint method actually returns a geometry.Point! not a java.awt.Point as documented.There is actually no way of getting around with a solution without this method.did I get myself an unstable release?!
I've started by looking at how you can draw a line from an origin pointing in a given direction. Don't be put off by the amound of code, I've just added loads of debug graphics which are added to the screen so you can see how I'm building up the picture. Let me know if this helps you get started.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
